still cant hook
simple question guys do yall think me at 360hp on motot and 495 on one kit is too much for the 255/50/16 mt dr do i need to goto a slick? if so ill do that and work from there...if yall think i can hook this im goana keep tweeking on it(iv been 1.45 before and i know heavier cars in the 1.35 range)
thanks for the imput guys
crashinaz-the car's not gonna do any worse with some more AS.????
I just see a quick bounce it there and it seems directly related to instant you loose some traction.AS - Anti-Squat. See if you can just pick up a set of cheap stock rear springs. I bet you'd be surprised with the results. You can work your way down to an acceptable height from there
I sawMADMAN on earlier make sure you shoot him the video
.Here let me talk you into it.
JUST DO IT!
ellis im sure hes seen this thread but ill pm him
i know on the subframes...im trying to decide which ones i want now, i dont know if i should tubular vs square, and cant find any in chromoly
shocks i think are too much for me to spend for a while
ive got some 15s but im geared for 26...can i still get some 26 for them or will i never hook 26's?
madman can you pm me a quote on subframes/price installed
or recomend some?
also watched when i put it in gear and can see the body of the car raise up about 1/2 inch....checked the lca angle tonite and its about 2.5
i just dont see why they are skipping like this....figured they wouldent hook or would...
none of this worked to i so i stuck some stock springs back in it set the pinion angle at -2 wolfe bar was both ends loose then tightened the lock nuts...18 psi in the tires...started ddoing a slightly longer burnout, maybe 4-5 seconds.....car went straight as an arrow and wnt 1.51 the first pass...from a prevous best 1.62 with the tire skipping
this was with a kid in a celica dragging water down the track in front of me..
got another pas and got a 1.4...felt great but was very smoothe i think my mom coulda done it seemed so easy and soft...
whn it comes down to it i simply think i need another hole in my lca brackets i think it was just the lca angle was only -2 and wasnt hitting the tires very hard and the instant center was prolly 5 fet in front of the car...
now i need some to cnc or cut me some new brackets to weld to my rear end with 6 or so holes to adjust my lca lower so i can get rid of this nasty rake it ahs going on and get it to hook with my lower springs...
anyone????
Well that and most of my suspension is stock, but I am still researching what I need...
Problem like you said, you can raise the torque arm up to hit the tire harder, but if you don't have the LCA in a low enough hole in the back it will put the instant center way forward, there is always a certain range you want it in for a particular car, if it got better by lowering the torque arm to the bottom hole then I would definitely do the additional holes, drop the lca one more hole, then try different spots on the torque arm.
Thing about adjustable parts is you have to adjust them to see what the car likes best. Don't forget to measure each hole hight and length and plot out where each one intersects, then you'll have a good idea where to start.
