how do you know when you need a rear drag bar? car acting weird?? help please
so i had some 28-10.5-15 mt et drags i wanted to try i knew they would be to tall NA but thought hell i might just get a front whell or two up so i tried them anyways.
well first launch i dropped at 6k and it poped the fronts about 4in![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
i was so pumped. well i stayed in it and when in 3rd it felt alittle weird like the tires were way out of balance so i let out
and ended up with a 1/8mile of like 7.5ish at 88 and my best before was (in my sig) high 7.3 at 98 so i know i could have gotten close to 10s ![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
well tried two more times at 6.5k and both times it almost jumped into the right lane ( i was in the left) i stayed in in the first time and when i hit second it jumped so hard it kicked me sideways almost lost it and hi thte wall.
third time it jumped very bad and i just costed the rest of the way.
i got a vid ill try and get up if it can last time i tried it never worked.
im not sure it i got a poroblem with one of the lower control arms there SPOHN HEIM HEIMs and maybe a heim went bad
or if the drag slicks are that much more i dont know what and i need a drag bar?
i have used ET streets before and this it the first time it has ever drated to the right like this any idea would be great thanks everyone
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
Your left rear tire is getting more traction than the right rear and pushing the car right. Which means that your car is unloading (squating) on the pass side rear. A quick fix is an air bag in the RR spring or like the above a roll bar. -Mark
LS1Tech Premium Sponsor
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Kind of hard to tell really from the video but I would lean more to the out of the groove scenario. If it continues to be a problem then it's in need of an anti-rollbar to plant both tires equally.
I guess you and I are the only people in here that read his post about adjusting the passenger rear control arm to get the 28" tire to fit. HELLO people the ****** rear end is crooked!!!
here is a vid of what the car was doing after lookin at it im not sure i just didnt get out of the grove?
http://media.putfile.com/wheelie-slow-0001
