Drag Racing Tech
Which tire?
Old Apr 21, 2008 | 11:38 AM
TA1364's Avatar
Originally Posted by RAGENZ28
People have been 7's/ 8's on bfg's, will they hold a 4,000 stall yeah, will they hold more power than pretty much any one has one here, sure with a tuned chassis.
People have run those tires with 1,500+ hp, so they will work for you to assuming you have your chassis setup right.
Well I have stock suspension. If they are so great why does everyone go with m/t then?
Old Apr 21, 2008 | 11:39 AM
TA1364's Avatar
Originally Posted by omcar
M/T drag radials..1.57 60' w/ 3,600 stall..no problem
Nice 60', to bad I cant get m/t radials right now or I would have.
Old Apr 23, 2008 | 11:19 PM
RAGENZ28's Avatar
Because the M/T is a newer more improved version of the BFG.
There are also brand preferences and of course legal tires in certain classes. If the hoosier or M/T are not available, the bfgs will work better than nittos.
Old Apr 23, 2008 | 11:32 PM
camscam02's Avatar
i went 1.55 on a 17 inch bfg drag radial 4400 stall and 4.10's fwiw!
Old Apr 24, 2008 | 02:32 AM
Almostryan3's Avatar
I have almost the exact same set up as you minus the LTs an I used M/T ET street (non radial)(26x11.5x16) and they worked great high 1.5 60's on motor and on a 150 shot still hooked fine with a low 1.4 60'
