car sits uneven
ive got afcos up front both of them are set ecactly the same...brand new...both are compressed 6 turns from the bottom
rear springs are stock without isolaters...i have lowering springs with the same problems back end sits about an inch differant....whats causing this
this is my car fender height at each corner in order
LF 25.75 RF 26.75
LR 27.25 RR 29
car has no bumper supports
no front swaybar
rear wolfe bar set loose
comp drag shocks out back
afco coil overs out front
is it ok to adjust the afcos enequally? and the rear springs cut them to make them sit evenly? or is ther something im missing about this?
2) shocks worn?
3) lca relocation brackets?
shocks are new comp engineering
yes i have relo bracekts (built into my rear end) but not sure how that would affect rideheight
It sounds like yours is a little more then normal though. Any chance that you have measured the tires? Check them with a string around the center, really the most accurate/only way to do it, see if there's anything going on there.
If you have swapped the rear, it's possible that the bracket that the spring site on on one side could be off a little, I've seen a few rears from moser that made the back of the car get raised up as much as 2 inches, but it was consistant for both sides, you might have gotten a really good one that preloads the car for you LOL.
Those guys that weld the rear end brackets on I swear built a jig out of sticks and rocks with the way they're so inconsistant... but that's another topic.
the swaybar like i said is loose...both end links can be wiggled right now
the springs perches seem to be the same height
also checked tires and pressure fronts are the same ar 45 psi and both rears are even and at 20
swaybar unhooked and hooked back up no differance...i have it adjusted where its hand loose on both ends also...
i dont know why its still an nch higher on the pass side...what else can i adjust...and its not the lca they are poly/rod and they twist easily....no binding on the rubber
If the height is still off then raise the left front spring. Mine was like this also until I shifted the weight. Keep in mind whether you lower the front or rear it will still effect the front or rear on that side and also some on the other side as well.
Undo the anti roll bar, adjust the spring until it is as even as you can get it then put on the anti roll bar and preload it slightly, in most cases the right rear will be about 1/4 - 1/2" higher than the left rear.
the lca can change height i know from today...one side was longer and was pushing up that side...i fixed it...it dropped 1/4 inch
