29x10.5W/Mini Tub/New Wheel Update
What spring did you end up going with? I got a 10" Afco from Madman, but ended up putting the 12 back in there until I get the right wheel with better back spacing. Your's looks god that way, but should be a little more stable if you can lower it over the tire a bit more. Of course that means re setting up your suspension all over (pinion angle, etc).
I still plan on going back to the 10" springs since the 12's are borrowed, but it will be more for adjustability and looks than performance.
But yes, 150# is the default spring and is probably perfect for a fly-weight car with an aluminum engine that has been gutted.
I see I have a 28" on mine now and my fender is about 26.75" off the ground, so mine is pretty low but when I go to my taller tire I will probably have the same problem, as is when I lower the car more for the 29 or 30" tire I won't have enough travel for the rear shocks so I have to go to a shorter one =/
Anyways get us some vids, that think looks fast
"The Drag Racing Director"
It is off a digital camera and was then compressed to go onto myspace. None the less, here is the link:
http://myspacetv.com/index.cfm?fusea...deoid=32765394
After looking at the vid, I see you lost the round. Good/Bad light? Run the number? Please give the racing details.
Tranz-brake? Delay box?
Coach
I tried pro this weekend (no box), but the air and track were awesome so even after pulling timing out, foot braking, and shifting like an old lady, I still ran below the 9.50 max.
Looks good. I almost started cutting mine out yesterday just mot sure if I want to use the wolf mintubs or put a full tub in it. I was going to use the tubs I got in the shed but do to the rust I will be ordering new ones.
