230" dragster with LS1
I went with the edelbrock vic jr. EFI manifold and a Holley 1000cfm Throttle Body to try and retain some of the traditional looks. Costs the same as a fast90/90 setup plus I feel it will perform better. I'm going to try and get it working with EFI live and MAP, ditching the MAF. I also have Precison Race Components Stg 2.5 5.3L Heads and the Magic Stick 3.
DD2000 thinks it will run 8.90's at out high altitude. Not a monster but it should be fun for my wife.
Any suggestion on how to make the engine look better?
Lee
http://i38.photobucket.com/albums/e1...s/IMG_0178.jpg
It will be differnt to have a dragster you can let sit and idle in the staging lanes all day and not have to work on it.
It should weigh 1550 with the LS1 and driver. It was 1450 with a traditional small block and I figure the LS1 should be 40-50 pounds lighter. DD2000 says 8.50 with the head/cam package at 6500 feet. I hate to get my hopes up but we'll see in two weeks!
Yes it will be cool to run pump gas! I wonder how many runs we'll get per gallon. I built a 632 for my wifes vette that was fuel injected and we got 3 runs per gallon while running 8.60's! What 5-6 runs per gallon?!
Have you weighed it without the motor and trans? I weighed mine with no motor or trans and it weighed 663lbs with the big *** wing on it that I took off now. It also still had all the electronics still in which I also took out.
Its true to a point. What he should have said is you don't need a lot of power to go fast with a dragster. Aero and weight mainly. LSX should be plenty fast!
I just sold my dragster a while back. 245in mike bos w/ a flat top 406 in it that might have made 450hp. went 860s @ 150 and 5.40s in the 1/8.
I'm thinking 450 @ the crank on your engine should be stupid easy, so yes, mid 8s should be no problem.
But after you get into low 5s in the 1/8, or mid to low 8s in the 1/4 you hit that wall where you need a LOT more power to go a LITTLE faster.
