Drag Racing Tech
LS2 Intake on LS1
Old May 5, 2008 | 12:51 AM
kdavis's Avatar
Default LS2 Intake on LS1
I have a friend who has an ls2 GTO. He is sellin his LS2 intake and cam. How well would the intake work on my LS1? I have a 99 Trans Am if it makes a difference.
The cam is 230-230-585-595@ 113. It is made for a LS2. Would this cam work in my 99 trans am?
Have any of you done anything of this sort? if so i would appriciate some advice.
Old May 5, 2008 | 06:37 AM
SSPerformance's Avatar
hmmm u try searching
Old May 5, 2008 | 09:01 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I was running an LS2 intake + LS2 rails in my Camaro and recently swapped to a ported FAST 92mm. I would go OEM LS6 intake over the LS2.
Old May 5, 2008 | 12:25 PM
1_bad_TA's Avatar
Sorry to hi jack, but why is that?
Old May 5, 2008 | 12:38 PM
LS1Tech Co-Founder
I can't find anyone that thinks the LS2 is as good as the LS6. I'd love for somoeone to say otherwise though.
Old May 5, 2008 | 12:40 PM
1_bad_TA's Avatar
Doesn't the ls2 flow more than the ls6?
Old May 5, 2008 | 12:43 PM
LS1Tech Co-Founder
I'm not really sure. I'd love to see a thread in one of the engine sections comparing the intakes. Matt and Bill seem to swear by porting the LS2 intakes though.
Old May 5, 2008 | 01:07 PM
1_bad_TA's Avatar
Thats were I heard it from then I seen what you posted. I still would like to try it. Alot cheaper than a fast 90/90.
Old May 5, 2008 | 02:10 PM
ONEBADWS6's Avatar
I offered to port yours for free John so you could do back to back testing.
Old May 5, 2008 | 02:16 PM
Matt D's Avatar
Retired Street Racer
I went faster, in worse weather, with a ported LS2 intake and 90mm throttle body vs a LS6 intake and ported 78mm throttle body. This was on my bolton car that makes peak power a tad before 6200rpm and shifts at 6500. A H/C car would see even more of a gain. But what do Bill and I know, our cars are slow!
Old May 5, 2008 | 03:15 PM
LS1Tech Co-Founder
Put one on this guy's car, see what it does. I went with the ported 92mm FAST because I'm working Ron @ Vengeance on the combo.
GS WS6's Avatar
LS2 intakes suck.....LS6 will make more power on any application
Old May 5, 2008 | 03:19 PM
kdavis's Avatar
What are some advantages and disadvantages of each?
Old May 5, 2008 | 03:34 PM
S8ER95Z's Avatar
Did a quick google...
http://www.vetteweb.com/tech/vemp_06...tor/index.html
The LS6 intake not only produced more peak power than the LS2, but it also outperformed the newer-style manifold from 3,700 to 6,500 rpm. We suspect that if the LS6 intake had been configured with a 90mm throttle opening, the difference would have been even more dramatic. Based on this test, it looks like (non-Z06) C6 owners would do well to swap out their factory intake for an LS6 unit.
http://www.vetteweb.com/tech/vemp_06.../photo_13.html
Old May 5, 2008 | 03:44 PM
Matt D's Avatar
Not if the LS2 is ported. Sorry, but it has been proven. Not just by me either, but others as well.
Old May 5, 2008 | 05:19 PM
CamaroAl's Avatar
We put a ported LS2 intake ,injectors & rails on Melissa GTO it made 310 hp
325 torque before swap then made 306 hp 335 torque
we lost 4hp but gained 10 lbs of torque and it kept the same power curve, we where happy it was a cheap swap for us to do
Old May 5, 2008 | 05:52 PM
kdavis's Avatar
I found an interesting website check it out.
http://www.gearchatter.com/viewtopic10974.php
Old May 5, 2008 | 07:20 PM
theblur98ss's Avatar
I'm under the assumption that the ls6 is better for na cars but the ls2 is better for boosted cars. Isn't Speed Inc running an LS2 on their shop car?
Old May 5, 2008 | 07:34 PM
kdavis's Avatar
^^^^This is what i think aswell
