Drag Racing Tech
Battery Relocation Question
Old May 9, 2008 | 06:17 PM
2000Z28M6's Avatar
Default Battery Relocation Question
Do you guys think it would be safe using 8g wire to relocate the battery?
I know the kits on the market use 2g, so thoughts?
Old May 9, 2008 | 06:53 PM
87Lt1Monte's Avatar
I would not even think about it...
Old May 9, 2008 | 07:11 PM
ROCNDAV's Avatar
I would use 4 gauge as a minimum, and the high quality stuff.
Old May 9, 2008 | 11:25 PM
RAGENZ28's Avatar
2 gauge minimum if it is located in the truck area.
Old May 9, 2008 | 11:29 PM
mrdragster1970's Avatar
6 & 8 Second Club
2 gauge minimum. Fine braid is better than the cheap kit stuff.
Old May 9, 2008 | 11:37 PM
RAGENZ28's Avatar
Yeah the welding cable is awesome. Fine strand audio cable is great but expensive as hell.
Old May 10, 2008 | 11:08 AM
James Montigny's Avatar
With that much current, you'll melt 8g in no time.
Perfect example of cable that will handle the task without issue.
Old May 10, 2008 | 06:04 PM
Blake01SS's Avatar
Ive always been told that Audio wire was not good to use? Can you use it without any problems?
Blake
Old May 10, 2008 | 06:07 PM
1_bad_TA's Avatar
Thinking about doing this aswell. Anyone have location and cutoff switch pics?
Old May 10, 2008 | 09:40 PM
6 & 8 Second Club
I thought I heard audio cable doesn't have a very tough jacket.
I know the kit I bought, like 20 years ago. Had crap *** wire. Big strands, jacket hard, didn't form where I wanted. The fine strand welding cable has a thicker jacket, softer, but tough, forms exactly as you need it.
Old May 10, 2008 | 10:48 PM
DOUBT IT's Avatar
Only if you like impromptu welding.
Seriously though, it should be 2ga minimum. Try and get 0ga welders cable if you can find it locally. Check out local welders supply shops.
Old May 11, 2008 | 04:41 PM
RAGENZ28's Avatar
Run the audio cable under the carpet, it'll last forever. You can run it next to where the power antenna cable runs and you'll never notice it.
