What is the NHRA approved way to attach steel roll cage to aluminum frame C6Z06?
Thanks...I'm not thrilled with the idea, but you gotta do what you gotta do if you wanna run it.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
We have a 25.5 C6Z sitting behind me right now. It was built by a friend of ours down at our shop to spec. It has it's sticker already. I would definitely check with your inspector first, as he did, because everyone might have a little difference of opinion on the matter. There is aluminum plates welded direct, drilled and tapped for 1/2" hardware and then the cage secured to steel plates.
![](http://www.ttperformance.net/benson/DSCN0872.JPG)
![](http://www.ttperformance.net/benson/DSCN0876.JPG)
![](http://www.ttperformance.net/benson/DSCN0786.JPG)
