new 11in narrowed moser with 15x12s
#41
If I could safely do it the way that you have it, I could pick up some much needed space, & have a better selection of rims to pick from.
#42
Are you worried about that binding up, as the heim joint is going to swivel & obviously cause the joint to contact the metal mounting point.. Might not be an issue on a drag only car, but might be on a street driven car, as mine is.
The only thing i had to do was trim the body a little so the the nut on the heim doesnt hit when it moves.
#43
See if you can verify this for me or not.. My 9in rearend has been narrowed. I was told by the previous owner that it was cut 3" per side for a total of 6".. Well I just put some 325/50's on the car and they wre rubbing the inner wheel wells and control arms sittin still. I put a set of offset control arms on it from Madman, but they were still rubbing the inner fender. The wheel is a 15x10 Alumastar with a 5" backspacing. It also has a 3/4" aluminum spacer on it already. Last time I checked 5" bs was correct for a fbody with a 10" wheel and narrowed 3" per side. The inner well had already been massaged and the bump stop removed, but that was nowhere near enough. I got a 3lb sledge and beat the **** out of the car for 2 hours until everything cleared good. It looks to me like the rear must be closer to 4" per side... Sound like a safe assumption??
It still has a good bit of room on the outside of the tire between it and the fender lip.. And probably an inch between the inside of the tire and control arm. Probably an inch or less between the inside of the tire and the inner wheel well.
#44
"The only thing i had to do was trim the body a little so the the nut on the heim doesnt hit when it moves"
Thanks, that's what I was refering to.. I'll just round the edge so it doesn't hit when it swivels.
Quick TA.. My car is mini tubbed, but I can tell you that with the 315's, I have about 3/4" between the tire & lca, with a 15x10 convo pro 5" bs.
#45
#46
15x10 on a 7.5 backspace is the right wheel for a stock lenght rear so IMO if you cut 3" off perside the correct wheel to keep the tire in the same spot would be a 15x10 on 4.5 this should fit with stock LCA, Now to run a 5" back space you would have to off set the LCA atleast .5" to clear but because you are running a .75" spacer this would make the wheel as a 4.25 back space and you should have plenty of room if not i would think the rear is narrowed more than the claimed 3"
#47
LS1TECH Sponsor / 7 Second Club
the key is interpretation of the rules. this car (from my understanding) utilizes the stock suspension location but not the exact suspension mounting point. what used to be the inner point of the lca mounting point on the car is now the outter with a new tab welded by chevpower.
atleast that is my take on this and LMR's car
#55
The pics above of the car with orange on it is a 15x12 with a 315/60 and i can slam it as far as you wish with out any problems, That car sits about 2" lower on a 30" tire than my whit car with a 28"
#56
All I see they are doing is narrowing the lower control arm mount on the axle tube and running no spacers that come with the heim ended lower control arms. The innermost plate is in the stock location and the move the outer side over.
You have to run spacers where the lower control arm mounts to the car.
I trimmed my inside plate on the body back so I could get to the adjuster nut.
I also re inforced it with 1/8 plate and welded it on.
David
David
#57
#58
on the orange one with the 315's you have a 15x12 4"BS on a rear that was narrowed 11"s right? how far in does your mini tub go? i want to run 315's and slam the car on them just like you have it. i have the rear in a shop waiting for me to tell them how much to cut off. i just just scared to cut too much off and not be able to fit the wheels i buy.
#59
