new 11in narrowed moser with 15x12s
#81
i am having some trouble trying to figure out what offset to get for my car, i narrowed the rear 10". 5" on both sides. i need to buy the wheels for it but i am not 100% sure what offset to get. i am thinking 15x10 with 4" BS.
#82
Sweet Pix Guys...
I recently had Madman & Company Racing minitub my 02 SS
I had my Moser 9" narrowed 3" per side and I now run a full set of
Billet Specialties 15x10 Rears with a 5.5" B.S. with 325 M/T-DR's
The 4.5" B.S. wheels would still hit the Offset LCA's. I also run
Strange Race Brakes. I can drop the car as far down as I like
without any problem. Also,... I am NOT running any spacers.
Here are a couple of pics
![](http://i34.photobucket.com/albums/d130/slp02ss/MRFYZ%2002%20SS/IMG_0689.jpg)
![](http://i34.photobucket.com/albums/d130/slp02ss/MRFYZ%2002%20SS/IMG_0692.jpg)
![](http://i34.photobucket.com/albums/d130/slp02ss/MRFYZ%2002%20SS/PICT0013.jpg)
![](http://i34.photobucket.com/albums/d130/slp02ss/MRFYZ%2002%20SS/PICT0039.jpg)
![](http://i34.photobucket.com/albums/d130/slp02ss/MRFYZ%2002%20SS/PICT0036.jpg)
![](http://i34.photobucket.com/albums/d130/slp02ss/MRFYZ%2002%20SS/PICT0104.jpg)
Hope some of this Helps
#86
hey guys i am running a 15x10 with a 4 inch bs with a 325 mt drag radial i have the car slammed pretty good, i am wanting to put a 15x12 on the car but not shure what 2 run for a bs?? i have stock location lca right now but have offset ones one the way,so that wont b an issue. also im running a stock spring set up and would like to put a mini tub spring set up but not shure what spring rate i should buy? also the car is not mini tubbed,i am trying to keep the car the way it is and not mini tub it?
this is a 325 before i lowered the rear
![](http://i725.photobucket.com/albums/ww251/fastass2000/047.jpg)
this is with a 28.5/10.5w
![](http://i725.photobucket.com/albums/ww251/fastass2000/12551_104596402888285_1000001377735.jpg)
![](http://i725.photobucket.com/albums/ww251/fastass2000/12551_104596399554952_1000001377735.jpg)
![](http://i725.photobucket.com/albums/ww251/fastass2000/12551_104561532891772_1000001377735.jpg)
#90
#91
Adjustable Shocks & Springs. In addition, I also had an issue with my Passenger side spring falling out at full droop. So, we added
2 pieces of 3" wide 30k-lb.Tow Strap, approx. 12-14" in overall length, bolted from the axle housing to the frame to prevent this issue.
It works better than chain, and it's a lot quieter too. This prevents the spring from just falling out at full droop.
Again, Hope this Helps!
#92
ok guys i messured my rear end it was 53 inches from housing end to housing end. witch i was told its narrowd 3.5 inches per side??? im looking to go with a 12 inch rim but wanna tuck it under the fender. i already have offset lower control arms. is this gonna hit the pan hard bar bracket with a 12 inch rim? what bs rim do i need??
