Drag Racing Tech
Narrowed 9" and Panhard Bar Question
Old May 13, 2008 | 09:17 AM
Z06kern's Avatar
Default Narrowed 9" and Panhard Bar Question
I'm trying to center my new Fab 9" from burkhart under my car. It seems that the panhard bar is to long and I cannot center the rearend properly. I run out threads on the rod ends to move the rearend over toward the passenger side of the car. Seems as though I'm going to have to shorten the bar by about 1-2 inches to get the right adjustment.
Has anyone ever had to shorten their panhard bar in order to center a fab rearend in thier car. The rearend has been narrowed 3" per side but I don't think that has anything to do with it.
Old May 13, 2008 | 09:30 AM
gator's 99TA's Avatar
I didnt have to shorten my PHR. mine was cut 3" off each side
Old May 13, 2008 | 09:32 AM
Z06kern's Avatar
Who made your PHR? I have a Wolfe. I'm just going to order some 1/2x20 tube adapters and shorten it. Can't see any other way of correcting the problem.
Old May 13, 2008 | 10:46 AM
Indukted1's Avatar
LS1Tech Sponsor
we have a car in the shop now that has a fab 9 under it and its shorten 4'' on each side, and didnt have any issues with the phr.If need be get a measurement and we will be happy to make you a phr that fits ferfectly!!
Old May 13, 2008 | 10:56 AM
NINET3Z's Avatar
I have a Midwest Chassis housing narrowed 3 1/2" per side and a Wolfe phb. It was too long also.
Old May 13, 2008 | 10:59 AM
Z06kern's Avatar
I thought I was going crazy or my car had some frame damage or something. At least someone else has had this problem. I will just shorten it. Thanks for the reply!
Old May 13, 2008 | 11:02 AM
Steve Burger's Avatar
LS1TECH Sponsor
Mine is shortened 3" per side. The PHB was fine. I would look else where before cutting it up.
Old May 13, 2008 | 11:05 AM
Z06kern's Avatar
What is the length of your guy's phb without the rod ends? That would tell me if the wolfe bar is to long.
Old May 13, 2008 | 12:28 PM
i have a standard BMR PHR with poly bushings. no rod ends.
Old May 13, 2008 | 01:33 PM
NO CATZZ's Avatar
I had to shorten mine about 1/2 inch or so when I put my narrowed 9 inch in. It was not a big deal for me because I have the lakewook PHB and it had plenty of threads left after I cut it. I would not worry about cutting it.
Josh
Old May 13, 2008 | 02:12 PM
FASTFATBOY's Avatar
I had to shorten mine, depends on who built the rear and where the hookup was put on the housing.
I had mine moved over, narrowed 3 inches per side.
David
Old May 13, 2008 | 03:11 PM
MADMAN's Avatar
LS1Tech Sponsor
Did you minitub the car?? You also need to make sure the panhard bar runs level when the car is at ride height. Anytime I minitub a car I move the panhard bar to the upper hole which calls for a shorter bar. I have them in stock.
__________________
www.madmanandcoracing.com
225-343-9029
LS1TECH Sponsor
Not sure on the length. It's the stock length I used when I had a stock length 12 bolt under it.
Old May 13, 2008 | 03:23 PM
Z06kern's Avatar
Thanks for the info Madman. I did minitub the car, what you are saying makes sense. I'm running all your suspension parts except for the PHR.
