Fiberglass T-tops
Thanks, Chris
All the work is basically in getting the factory hardware off your (or a set from the junkyard of) t-tops.
You break the glass, scrape it off the plastic...
Latch the glassless hardware into your car...
Set the roof on top.
Mark on the brackets where you need to drill holes for our provided hardware...
Drill the holes and bolt the brackets to the top
