questions about nuts and studs...
now I'm looking at 1/2" studs for the rear but theres a few different ones on summit, not sure what knurl length i need/want nor what knurl diameter...
basically I'm pretty damn confused on what rear studs to run.
ARP-100-7703 knurl diameter = .0625 knurl length = .400 underhead 3.500 in.
ARP-100-7705 knurl diameter = .0680 knurl length = .400 underhead 3.125 in
ARP-100-7706 knurl diameter = .0568 knurl length = .710 underhead 2.970 in.
ARP-100-7707 knurl diameter = .0618 knurl length = .800 underhead 3.050 in.
i'm pretty sure the 7703 is the one I want because its 3.5" correct? other than that im lost.
what about lugnuts?
Chad
or could I change them to press in?
Chad
its either that or remove the 9 inch completely and get the axles pressed off?
Chad
my axles are already drilled for 1/2" studs in the rear, so all I need to do is drill a hole in the backing plate where the sensor is suppose to be to fit those big ol nuts in the hole
Chad
You got it, drill the hole in that spot and you can slide them in through there. It's going to be a bitch getting those pressed in studs in all the way though. I've never done pressed in studs on the rear with the axles in. I like the threaded axles for that reason.
Good luck...
Good luck...
Chad
