Drag Racing Tech
Spohn 1" sway bar,will it be enough?
Old Jun 5, 2008 | 05:06 PM
StreetStalkerZ's Avatar
Default Spohn 1" sway bar,will it be enough?
I'm ordering a rear sway bar in a few weeks to help control the car better on the launches. I am going to start daily driving the car again in a few months and need to know if this sway bar is beefy enough for high 1.3 60fts.? It might not ever see that as heavy as the car is but it has gone low 1.4s before.
Old Jun 5, 2008 | 07:11 PM
GM Muscle's Avatar
Your going to have to play with cutting the link spacers to preload it. Otherwise, your still probably not going to leave flat. I would have rather saved my money for an adjustable bar.
Old Jun 5, 2008 | 09:19 PM
JL ws-6's Avatar
Race your car!
I had one of those bars a while back, it was a definate improvment over the stock bar, but it's no drag swaybar that I can tell you.
For a street car that sees the track, yes not a bad move, for a car that sees alot of track, and you are making enough power to need the chassis preloaded, it's not gonna cut it.
Old Jun 5, 2008 | 10:38 PM
Matt D's Avatar
Retired Street Racer
I have this same bar on my car and I go high 1.3 60fts. Bolton LS1 with a dry shot in the air lid and 275/60 drag radials. I simply bolted it up. No modifying whatsoever. Car leaves straight.
Old Jun 6, 2008 | 03:55 AM
tektrans's Avatar
^^^she may leave straight but she's twisted.
More power you make it will get worse.
I have the spohn dragbar, if you can return the 1" then do it, otherwise you'll probably have to run a passenger side airbag to preload that side.
Old Jun 6, 2008 | 06:05 AM
I might have to wait and get the adj. sway bar. Is there any welding to be done on the spohn or BMR unit?
Old Jun 6, 2008 | 06:19 AM
junior28570's Avatar
no welding on the Spohn .. not sure on the BMR
Old Jun 6, 2008 | 06:24 AM
jmill96Z's Avatar
I'm subscribing to this one. I cut high 1.3's on a stock sway bar, but my car is twisting like chubby checker. It twists to the point that it unloads the driver side tire if I have less than 30 psi in the passenger bag. This bar seems like a good alternative for me, as there aren't any chassis shops up here that I would trust to weld a drag bar on for me.
Old Jun 6, 2008 | 06:38 AM
82 camaro's Avatar
What about a TRZ bolt in bar.
Old Jun 6, 2008 | 06:48 AM
jmill96Z's Avatar
Could you PM me a link?
Old Jun 6, 2008 | 06:56 AM
JL ws-6's Avatar
Race your car!
TRZ you still need tabs welded on, but it's a nice looking piece.
Old Jun 6, 2008 | 07:01 AM
tektrans's Avatar
There is some welding yes, where the endlinks bolt up to the frame you bolt them in like the stocker but then you weld the brackets as well.
You can install the bar yourself then just drive over to a repair shop, muffler shop etc. and ask them to weld the brackets for you if you don't weld.
Old Jun 6, 2008 | 09:16 AM
BMR Tech's Avatar
There is some welding involved with our anti-roll bar but nothing terribly complicated. This system has produced 1.19 60' times and mid 7 second time slips.
Attached Thumbnails Spohn 1" sway bar,will it be enough?-xsb001.jpg   Spohn 1" sway bar,will it be enough?-dragbar-installed1.jpg   Spohn 1" sway bar,will it be enough?-dragbar-installed2.jpg   Spohn 1" sway bar,will it be enough?-dragbar-installed3.jpg
Old Jun 6, 2008 | 09:24 AM
jmill96Z's Avatar
Any chance for a discount???
Old Jun 6, 2008 | 03:14 PM
82 camaro's Avatar
http://www.trzmotorsports.com/
Here is a link
Old Jun 6, 2008 | 03:46 PM
bigsticksupra's Avatar
With a the BMR drag bar, can the car still handle well with a proper front swaybar?
Old Jun 6, 2008 | 03:51 PM
chrs1313's Avatar
1" solid in the back of my car but i have a passenger airbag with about 40psi too...
Would definitely get a drag bar if you got the money...
Old Jun 6, 2008 | 04:04 PM
landonew's Avatar
By handle do you mean DD? Yes. IF you get the BMR extreme sway bar, and the BMR front sway bar your car will handle fine for commuting purposes. Wouldn't suggest you do any road racing, but it is safe on the street.
Old Jun 7, 2008 | 02:29 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I'd get the BMR rear drag bar, 1.3's for me, and it leaves room for the adjustment ***** on drag shocks.
Old Jun 8, 2008 | 09:23 PM
1BADAIR's Avatar
you could also just remove one endlink while street driving. I am getting ready to but the Spohn
