Need some advise on launching
QA1 R in front 300lb spring (setting 1)
QA1 rears 150spring with adjustable mount (setting 6)
Spohn drag bar
all the chassis stuff
Stange 12 bolt spool 4.10
M/T 275/60/15 drag radials
here is my question: when i lauch ,my rear passanger side is squating bad and i am lifting the front drivers, thus unloading the drivers/rear tire (spinning 50/70feet)
What should I adjust??
I am running a 150 wet N2O off the line. I dump the clutch at 3500rpm
If your springs are adjustable you can stiffen them up as well but with the spohn you have to adjust them evenly on both sides.
Took me 3 1/2 full turns to get her to go straight from zero. If you rolling over that much I still think 2 full truns is a good starting point, if you start going left you could always dial it back but starting with 1/2 turn incremements certainly is another option.
Preload refers to how much the link is turned on the anti roll bar to apply more force to that side of the car. If both of the bolts can slide in and out easy that is zero preload.
The rear end twists when the car launches and pushes down on the left tire and tries to raise the right, the body shifts back and to the right. You preload or lengthen the right side link until the effect is countered.
It's easiest when you have it on scales, then you can preload the bar and see the actual changes with the weight on each tire. Without scales I would just install the anti roll bar and give it about a 1/2 turn to lengthen the passenger side link and launch the car, then add a little more length until it leaves and runs straight without squatting to one side.
No car is the same, some cars will work with 1/4 turn, some need 3 or 4 full turns or more, there are a lot of variables. Just put it on and adjust it until the car leaves straight and level, there is no magic setup or number of turns, adjust it till it works best for your car in small 1/4 - 1/2 turns until you get your best 60fts.
When you adjust the preload you should be in the car when it is done.
