Drag Racing Tech
SYAB don't fit
Old Jun 29, 2008 | 12:41 PM
LS1SpeedAddict's Avatar
Default SYAB don't fit
Anyone have problems with their SYAB not lining up? the tabs that are supposed to bolt to my K member don't line up. Could this be because I'm running a PA tubular K member?
Old Jun 29, 2008 | 01:13 PM
TwoFast4Lv's Avatar
Mine bolted right on my PA K-member.
They use one of the chassis bolts. I will go see if I can snap a pic or two
Old Jun 29, 2008 | 01:33 PM
TwoFast4Lv's Avatar
Old Jun 29, 2008 | 04:05 PM
Coach 02 A3 Z/28's Avatar
"The Drag Racing Director"
Mine are the same as the pics.
Coach
Old Jun 29, 2008 | 04:42 PM
TXCAMSS's Avatar
"All Motor 9 Second club member"
The SYA bars for the PA K-Member are not the same as the BMR and other K-Members. Give Madman a call.
You need to specify which K-Member you are running so it'll bolt right up and have enough ground clearance.
G/L
Old Jun 29, 2008 | 04:54 PM
red83's Avatar
From: sneaking in your back door as you leave!/cartersville ga
he didnt ask me which one i had????????????? i had to modify mine before i put mine own. mine would not sit right on the crossbar on the k-member.
Old Jun 29, 2008 | 09:41 PM
I'm gonna try it again tomorrow. I was considering switching to a spohn K member to run solid motor mounts. So I was hoping if they don't line up with my PA the would work with the spohn.
Old Jun 30, 2008 | 07:06 AM
koolrayz's Avatar
I have the PA. Mine didnt fit. Do you have tubular A arms? I dont, Madman said that why they didnt fit?
Didnt matter because with the big Kooks headers they didnt extend down far enough. I just cut the tab with the bolt hole off and put an extension in the tube and welded it up. not that big of a deal.
Old Jun 30, 2008 | 08:53 AM
I have tubular A arms
Old Jun 30, 2008 | 09:20 AM
Tony Shepherd's Avatar
Mine fit fine with the PA K-member
Old Jun 30, 2008 | 09:57 PM
And so did mine today , we were lining them up with the wrong bolt holes . Guess thats what happens after you worked 12 straight hours.
Old Jul 1, 2008 | 12:15 AM
TwoFast4Lv's Avatar
Glad to see them on I had a feeling that was...i thought that is how they went on also LOL!
Old Jul 1, 2008 | 08:53 PM
Thanks for the pics!
