how bad does a Dirty airfilter hurt performance?
run the car w/ the filter off. that should give you a hint.
Remove filter. Brush off dirt and crud with a soft brush and shake off as much crap as possible. Spray cleaner (or any good detergent) on dirty side of filter (outside). Let it soak for 10-20 min. Then rinse out with low pressure water from reverse side. Shake it off and let it air dry (another 20-30 min). Then spray it generously with the K&N oil (that red oil...) Let it dry and respray any spots that the oil didn't stick to. Should be red again now and clean. Good to go!
Do this every oil change or whenever you see it looks dirty. You'll help you MPG and throttle response.
tight for money untill next week. or i would. i just kinda remembered today i havent cleaned it in a while and its as black as the rubber seal around it lol.
Plus, with gas so $$$, every MPG is worth it.
Do it! lol
Watch out on the filter oil, I Work in a Chevrolet dealership where i've seen quite a few k&n filters with filter oil getting on to the MAF sensor causing driveability concerns. There are also Gm service bullitins describeing this same concern.
Heres the bigger concern, once a MAF sensor has been contaminated (with anything) cleaning them does not seem to work very well.
So my advice is use the filter oil "lightly"
Just trying to help everyone out
anyway ive proven this on 2 differnt cars mine and my buddies both gained 1 tenth and 1mph by removing the air filter at the track....
