Drag Racing Tech
Sway bar Question
Old Jul 11, 2008 | 05:44 PM
Merciless's Avatar
Default Sway bar Question
I'm going to disconnect the front stock sway bar for the track. Would it be beneficial for me to upgrade my rear sway bar or should I just leave the stock one in?
Thanks
Old Jul 11, 2008 | 07:37 PM
TheBlurLS1's Avatar
That's what she said...
With the 1" rear Spohn bar, and no front bar, my car handles almost as good as stock (from what I can recall lol).
Old Jul 12, 2008 | 12:05 PM
chrs1313's Avatar
exact rear sway bar helps me a ton at the track with my launches...
Old Jul 12, 2008 | 04:01 PM
Merciless's Avatar
any numbers pre and post?
thanks for the info guys
Old Jul 12, 2008 | 04:19 PM
chrs1313's Avatar
helped me about a tenth in the 60 ft...was in the high 1.5 range because i was twisting the rear chassis over and causing the rear tire to lose traction...now well i kinda destroyed the cam only 60ft with my power and weight...with stock gears too...
Old Jul 12, 2008 | 04:35 PM
BOLO's Avatar
Chrs1313, is that with the stock 10 bolt?
I'm thinking of getting one.
Old Jul 12, 2008 | 07:04 PM
chrs1313's Avatar
yeah sure is..the rear is 100% stock untouched...u just have to tilt the saddles back a little to get it to clear the rear cover...i got mine for like $150...i do also have a rear air bag in the passenger spring with 40psi
Old Jul 14, 2008 | 05:05 PM
TheBlurLS1's Avatar
The Spohn swaybar mounts are a must with this bar. I had to tilt mine back too, and I've got a Moser 12-bolt with a girdle.
