Looking for traction, can I get some help
Just did the hose mod to the rear springs hoping to level the car out a bit, did nothing for traction. Unless I come off the line super easy I have no traction until the very top of first then loose it again on the 1>2 shift.
Where should I go next looking for this traction stuff? None of the sponsors seem to sell this stuff by the gallon. What do you all suggest I try, shocks?, 15" wheels?, I sure as hell dont know.
Now have you played with tire pressure with the BFGs, most DRs don't like more then 18 psi, i know my MTs didn't, also put the LCAs in the lowest hole on the bracket, this will plant the tires harder & should keep them there, i would do those 2 things 1st. & see how it does, if it really doesn't cure it, then go the other route.
Tank is usually pretty full when I race, I fill p before I hed out to the "track". I was considering doing 373 gears and a 28" tire, for sidewall flex, but am not sure if that will hurt at the tall end of the 1/4 mile.
Lots of question, but these all could lead to less than optimal traction besides your car and its setup...
X2 it would help to see an angle from the rear looking down the side so you can see what the body does on the launch, i.e. roll right, front lift, rear squat, etc. Also, with my LCA on the lowest hole it put my IC behind the driver causing the rear to lift when launching, I spun no matter what the tire psi above 3000rpm. After reconfiguring the TA and LCA's it loves 5600 out of the hole, to bad I don't make enough power N/A to do anything cool!
I think its funny all the guys around here go to the street legal Friday nights and the dew has set in and they are spinning bad and cant figure out why
When I had my Jegster tunnel mount on the car, I had to launch it different. If I left off-idle, the car would absolutely ROAST the tires. However, if I stalled it up somewhere in the 2500-3000 range (on a 4000 stall), and kinda "hitched" it outta the hole, it would launch to 1.6x's on DR's, and consistent 1.7x's on street tires.
What I describe as a "hitch" goes like this. Stall the car up to about 300 rpm below where it'll break the tires loose. You have to do this right before you launch, otherwise you'll balloon the converter. When the light drops, you let off the brake, then the front end will drop slightly, then pick back up. When it starts to pick back up, do a "fast" roll into the throttle, just enough not to roast the tires. All this happens in less than a second, and you have to get the timing right, but that's how I launched for years, with nothing but traction.
Here's some videos of my car launching, so maybe you can see what I'm talking about:
On DR's
http://videos.streetfire.net/video/T...908_153519.htm
On street tires
http://www.youtube.com/watch?v=meTnn4zr1Ck
I do have a different TA setup now, so I launch at about 1100 rpm, then flash the converter.
Best thing I could tell you to do though is to practice, and learn how your car likes to be launched.
On DR's
On street tires
I can't control how other people film my car. I try to get them to do what I want, but it never happens that way.
