Drag Racing Tech
wheel studs
Old Jul 28, 2008 | 12:21 PM
Dave J's Avatar
Default wheel studs
with skinnies up front how many threads of grab on the lugs would you guys consider safe
Old Jul 28, 2008 | 01:13 PM
ALLBOTTLE's Avatar
LS1TECH Sponsor
you should have the same depth as the diameter of the stud at a very minimum.
Old Jul 28, 2008 | 02:43 PM
TwoFast4Lv's Avatar
we should get that in the sticky
Old Jul 28, 2008 | 08:30 PM
TXCAMSS's Avatar
"All Motor 9 Second club member"
I think as an engineering rule of thumb it should 1.5 times the diameter of the wheel stud.
A very wise man once shared that info with me.
Old Jul 28, 2008 | 09:46 PM
SPEEDYws6's Avatar
Usually what ever the diameter of the bolt or stud, but on wheels I would go with the 1.5 rule.
Old Jul 28, 2008 | 11:06 PM
ALLBOTTLE's Avatar
LS1TECH Sponsor
All wheel studs (not just on the drive wheels) must extend into the hex portion of the lug nut a distance equal to the diameter of the stud.
Per NHRA rules
Old Jul 29, 2008 | 04:40 AM
JL ws-6's Avatar
Race your car!
IMO, if the stud sticks out of the end of the lug you're good.
I know blah blah your street rims will look funny, but I'd rather have that problem then have a wheel melt off the car because ya tried to get away with too short a stud.
Old Jul 29, 2008 | 09:19 AM
Dave J's Avatar
I am going to give the arp 2.5`s a shot in the front they should be plenty big enough
Old Jul 29, 2008 | 09:32 AM
mrdragster1970's Avatar
6 & 8 Second Club
Diameter of stud is actually one of the better NHRA rules. Easy to remember & more than strong enough to be safe.
Old Jul 29, 2008 | 09:34 AM
7420NW7TH's Avatar
The ARP studs have a tensile strength of like 180kpsi or more which is alot more than the grade 8 stock studs. That alone should make you feel good. The 1.5 rule is a good rule of thumb for thread engagement. If you think about it, the summation of the thread shear area will be greater (using the 1.5 rule) than the crossection area of the bolt itself, meaning that the bolt will shear before the threads shear. So, with the 1.5 rule you know you are good. 1/2" arp studs (x 2.5" long) should be good for most all applications. Unless you are running single digits then I would go with 5/8" studs.
Old Jul 30, 2008 | 10:24 PM
Villain281H's Avatar
7 Second Club
From: Gainesville, Florida # of drag strips runs: ?!?!?
Added to the sticky: www.ls1tech.com/forums/showthread.php?t=880990
Derek
Old Jul 30, 2008 | 10:54 PM
CamaroRacing12's Avatar
ok, i am going to lay it down for u right now... i have done 30 studs on my car in the past month because of this crapola!
2.5" arp's are more then safe.... but they r not IHRA/NHRA legal
if you are running weld skinnies with a spacer up front... the 2.5" will be like 5 or 6 mm too short (i kno ****** bullshit) go with the 3.25" to avoid any issues... im installing 2 sets friday. i hate bullshit rules...
i think that rule should only apply to the rear wheels... all the stress is on them (burnout, launch, etc) the front have some stress (weight) but thats about it... 5mm should not make a freakin difference!
so basicly to be legal and not get any ****... if ur running welds u need 3.25" in front and 2.5" in rear...
Old Jul 31, 2008 | 06:12 AM
7 Second Club
Just my $.02, but wheelstands don't cause any stress??
Old Jul 31, 2008 | 06:28 AM
Fireball's Avatar
what if a car starts darting one direction and you have to steer to compensate...thats alot of side force on front studs too...
Old Jul 31, 2008 | 07:33 AM
JL ws-6's Avatar
Race your car!
Told ya you would need the longer ones.
