Drag Racing Tech
Help with ET Streets - Trouble Hooking
Old Aug 4, 2008 | 11:25 AM
105's Avatar
105
Default Help with ET Streets - Trouble Hooking
I went to the track friday and made 3 NA runs and every time I spun horribly. 2.0 60's. I've get 2.0's on my street tires! I launched from 5.5k, 5k, and 4.5k rpms. I did a nice smokey 2nd gear burn out each time with my new line lock. I started out a 16 PSI but it went up to 18 after the first run. I took it down to 15 PSI after that and still spun. Should I go lower on the PSI or maybe lower RPMS?
Tires: MT ET Streets 28X11.50-16LT (non-radial)
all mods in sig except I didn't spray. front sway endlink removed
Thanks
Nick
Old Aug 4, 2008 | 11:32 AM
02SOMWS6's Avatar
11-12 psi.
http://photosbyjim.smugmug.com/galle...011_ApYpD-L-LB
http://photosbyjim.smugmug.com/galle...587_2tnb6-L-LB
11 psi in these photos. I have gone as low as 9.5 Don't worry about the low psi., by the time you do your burn out and stage the tire psi has gone up 2 to 4 psi depending on how hot the track is. As far as your burn out do a short spin in the water to get the tires wet then pull foward and do your burn out
Old Aug 4, 2008 | 11:38 AM
kdavis's Avatar
yea that^. i used mine at 13 psi and spun. the way the track that i go to is set up you back into the water pit and spin them then pull out and do the burn out. here is a link to a video.
http://www.youtube.com/watch?v=CnVlsRDx98w
Old Aug 4, 2008 | 11:56 AM
LM97Z's Avatar
WAY too much air for a bias tire, your running DR air pressure, start at 13 & drop 1 psi at a time from there.
Old Aug 4, 2008 | 12:01 PM
Dave J's Avatar
I run 13 psi(cold) in my 26-10.5-15 et drags(1.46 60ft) you should be close to that in et streets
I have the same suspention as you except I have qa1 shocks all the way around
Old Aug 4, 2008 | 12:19 PM
105's Avatar
105
Thanks for the advice. I'll give the lower pressure a try, hopefully this friday, and let you all know how it does.
Old Aug 4, 2008 | 09:36 PM
02SOMWS6's Avatar
Don't forget that tire psi. that works for a auto won't always work for a stick.Start at 13 psi for a starting point and drp 1lb. at a time
Old Aug 5, 2008 | 03:21 AM
2XR95Z28's Avatar
Are you guys running at 12-13psi with tubes or without?
Old Aug 5, 2008 | 03:18 PM
mike c.'s Avatar
I hate m/t tires(dont hook for me) but,I run my slicks at 12 to 13psi cold do my burnout and l launch at 5,000 to 7,000 they hook where ever I want and go. 1.42 60's on a m6 3,700lbs car. I run M&H Racemasters 26x11.5x15 cheeter slicks w/tubes www.intercotire.com
Old Aug 8, 2008 | 09:50 PM
105's Avatar
105
Default update
I did a lot better tonight. I started at 12 PSI cold and spun a little. Next 12 PSI hot spun a little less. 3rd run 11 PSI hot, 5800 RPMs, dead hook and lifted the front end, but then bogged down to like 3k. 1.8 60'. I wish I could've ran more. My car has never hooked that good before! I might actually spray it next time. Thanks for the help guys!
Nick
Old Aug 8, 2008 | 10:17 PM
02SOMWS6's Avatar
Nick
Nice, launch on spray and that bog will go away. I launch at 6,00rpm when I spray but every car is different. I also pull 1.4 60ft.'s
Old Aug 8, 2008 | 11:21 PM
the_merv's Avatar
Mid 1.5 60ft's at about 12psi, 3600 Stall, 3.73 Gears, 275/50R15 MT ET STREETS.
Old Aug 9, 2008 | 07:59 AM
02SOMWS6's Avatar
what works for a auto won't work for a stick car
