Summertime boredom, how about some new wheels :)
I paid 1200.00 for the rears new, not cheap, the guy who had them done had 1400 in them total. They were beadlocked by OMF in California but there are a lof of other places that do beadlock conversions, reds, champion, sheppard etc. Weld sells wheels already beadlocked also but they are like 900 each for a 10" double beadlock wheel.
I dont remember what the front wheels were, I bought them when they first came out and they were 240 each or something.
I have the 2.25s but may swap to the 1.75s, they look a little too much in the wheelwell but it may be that I'm used to seeing the car with the LS Bogarts that they were maybe 1.5" BS if that so it looks weird to me.
#33
But the moser TA isnt fixed, if you mean fixed as in it doesnt slide.
The TA mount I have is adjustable in the front for height but since it slides, moving it up and down you are not changing IC.
#34
Coal Mining Director
My rough way of lookig at it:
Moser/Madman slides without an arc and you can set/ change IC.
RT/Spohn,etc arc and don't let you set the IC.
RT vs Moser in your car would be interesting. Especially with you tuning the suspension.
#35
I doubt either way I'm going to best 1.25 60's by much with the same amount of power. Main reason I'd like to switch to the M9 is to save about 40lbs over what I have, plus I dont think anyone else has ever gone in the 8s on a RT arm with a poly bushing in the front and I'm a little paranoid about something failing, even though it seems to work just fine and still looks like new after three years of beating. I'm sure the poly bushing takes some of the shock off the rest of the TA hardware, and the arm itself, on a launch.
#36
my spohn must be diifferent compared to a RT. As the ta moves, the front mount is a bracket that slightly moves the ta up/down through an arc. Madman/MOSER only moves in/out of a tube and can't go up or down.......supposedly allowing a fixed IC depending on the end location in the bracket. Myth?
#37
At least thats how I understood it all to work
Here is a calculator for IC on a torque arm car, only thing they ask about the the torque arm is the length itself (which does change IC some), not the height. The lower control arm heights are the the main thing.
http://home.earthlink.net/~whshope/id28.html
I forget the guys name that wrote it but I read a very good book on torque arm suspensions years ago. It was more road race oriented than drag race but it laid out exactly how they work and what changes what as far as dive under braking and anti squat under power. For the most part though he mentioned many times that a torque arm is NOT a three link or ladder bar and the height of the front TA mounting point doesnt change anything in respect to IC.
Give you something to think about anyhow
#38
This book?
http://www.amazon.com/Race-Car-Vehic...0161043&sr=8-2
Also, the adjustable link that is added in the front essentially acts like a 4 bar mechanism. I guess i'll have to doodle something up so it makes sense.
#39
This book?
If you read and understand the first post here then you will understand what I'm saying:
http://www.pro-touring.com/forum/showthread.php?t=14977
I have debated this to death several times and dont want to get into it again, whatever works for you
