Drag Racing Tech
What heads to run on a 383 solid roller???
Old Sep 1, 2008 | 09:34 PM
cbra-klla's Avatar
Default What heads to run on a 383 solid roller???
I planned on doing a 408 over the winter but since i am doing a TH400 swap so late in the season, i think i might go ahead and build the stock motor.. I am planning on stroking it out and pouring the nitrous through a direct port to run some heads up racing in the 1/8th mile..i am leaning towards a solid roller setup, but im not completely sure yet...What would be my best bet??
Depending on money, if i have to go with a cnc'ed stock casting, what should i go with...
By the way car already has full suspension, awaiting the Th400 w/ transbrake now..9" rear.....etc.etc.etc.....
Old Sep 1, 2008 | 10:04 PM
mike#9's Avatar
You may look at a set of Darts, PRC's....or maybe Trickflow............depending on budget and what not
Old Sep 3, 2008 | 01:48 AM
silverbeast's Avatar
if you have the coin go with the TFS or AFR heads.
Old Sep 3, 2008 | 01:53 PM
82 camaro's Avatar
Dart 215 or AFR 210 eliminators and a soild roller cam..
Old Sep 3, 2008 | 03:57 PM
GueSS Who's Avatar
I have Dart heads on my solid roller and it made 601rwhp through a glide and 9in. Don't use stock casting on a solid roller. It is not worth it.
Old Sep 3, 2008 | 05:02 PM
cbra-klla's Avatar
my buddy has a new set of dart 225's i can get for a great deal..may go with them
Old Sep 3, 2008 | 07:46 PM
James Montigny's Avatar
Dart, TFS or AFR, then have them ported.
Be sure to tell the porter what you are intending to do with it.
The cam should be designed to compliment your goals and rest of your setup.
Old Sep 7, 2008 | 12:29 PM
cbra-klla's Avatar
definely going with the Dart 225's ...just need to figure out what pistons and cam i should go with now...i would like to really get the compression up there..i wouldnt mind running a blended fuel when i spray it...
