Sooo close! what can i do?
My set up is a 95 Z (LT1) mods are, K&N FIPK, Hooker cat-back, !cat after y-pipe, 3200vig stall, and ET Streets. i also have !backseats and !sparetire and jack.
I have no trouble hooking up, so i just want to know if there is anything easy i can do to get me the lil extra bit.
any help?
Hell even ditch the side seat, every little bit helps.
You can put it all back in when your done, except the padding.
And if you did the backseats, I hope you did the rear seat belts.
Also overflow tank and washer fluid.
Back seats, rear carpet padding, floormats, sparetire/jack, front swaybar, panels in the hatch area, drain your wiper fluid .......
It adds up quickly.
Don't show up to the track with a full tank of gas. You can make quite a few passes with 1/4.
Leave the laptop, tools and jumper cables at home or in someone else's car while you race.
Hell, be sure to take a good **** before you leave home for an extra few lbs LOL
You can also try pulling the air filter and/or running beltless.
(I wouldn't do the beltless thing for more than one pass with a short wait in the lines unless you know how long your battery lasts at WOT)
Nice cool air helps too, I dropped almost .20 off my time from one weekend to the next last fall.
Keep in mind that anything you take off, could always be put back in if you wanted to.
I put my seats, spare, swaybar and trunk back together if I don't plan to go race again the next weekend.
Heh, I usually have a pair of child's carseats and a few toolboxes in there too.
Also heat shields, if you have deleted the cat, they are useless.
CHECK OUT MY POST!!!
https://ls1tech.com/forums/drag-racing-tech/982188-weight-reduction-questions.html
this will give you an idea of what I am doing
Any other ideas let me know. Thanks alot for the ideas so far!
i have 300 lbs off of mine. every 100lbs=1/10 gainedto the person who asked about the carpet fitting without insulation, i removed the insulation off of mine and it fits just fine. my interior looks stock as a bone
Hell I pulled out a good couple hundred pounds last season when I pulled the AC, radio, PS, airbags, and relocated the alt, I have since pulled even more weight out, but like I said it all depends on what you think you can live without...
run beltless, try to get run w/ a 1/4 tank of gas... hell even mix in a lil 100 unleaded octante in your fuel tank
did you do the tb bypass mod?
a good tune up
