Hoosier 26x10x15 better than Et drags?
I've been running a set of M/T 26x10x15 ET drags and was debating on switching over to Hoosiers (same size). What do you guys think? I've always heard that Hoosiers hook better than M/T's. I just wanna hear it from people that have actually ran them.
Thanks
Thanks
i've ran both tires and i personally think that the m/t hooked a lot better. each person will have their own opinion on this one, so it may be hard to get a real good answer. your best bet is probably to try out the hoosiers and see which you like better.
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
I have the hoosiers in that size, and granted I have awful track prep in AZ, but I can't hook up dropping the pressure down to 13.5psi hot...and that's with a lower inertia aluminum flywheel.
Granted I'm launching at 7K Rpm's w/ 440rwhp
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
I tried a set of 26x9 hoosier drags Vs. my 10.5 ET Streets i used to run and cut the same 60fts. Now with my ET Drags i hook atleast .03 faster at the 60ft. Vs. the ET Streets and Hoosier Drags.
