Drag Racing Tech
Car wont transfer wieght. How much weight needs to come off the nose?
Old 11-09-2008, 09:11 PM
Packy's Avatar
Mine used to do something similar. I put Hal QA-1's in the rear [set on 4-6 depends on track conditions] since I already had them on the front [set on 4] and upped my tire pressure to 15psi warm to fix it. I run 27 x 11.5 Hoosier QTP's though. I don't have have near as much wieght reduction as you do though. The only thing I have done is removed my front sway bar and put my full size Optima battery in the rear where the spare used to be.
Old 06-10-2009, 02:17 AM
joblo1978's Avatar
Yeah, I'm not an expert, but get the car scaled or see what you can do yourself to get the rear down a bit more or front up, level it out, looks like you got some rake. You're faster than me for sure, looks like you got lots of potential there.
I noticed you aren't launching really straight. Maybe adjust your LCA's to square the rear up with the car if it's not already.
Old 06-10-2009, 02:57 AM
Sharpe's Avatar
So, no updates in 7 months...
What did MM say?
Old 06-10-2009, 11:34 AM
SPEEDYws6's Avatar
Well the car is way different now chassis wise. I was out of gear so I decided to go with a taller tire (29.5x10.5). Madman scaled and squared the car and it leaves straight as an arrow now. I don't make it to the track very often, still trying to figure out what the car likes. And I'm still trying to learn this stuff.
Old 06-10-2009, 11:41 AM
SPEEDYws6's Avatar
New stance,
Old 06-13-2009, 04:10 PM
mike c.'s Avatar
Z28BERRYHILL-It's only 14lbs not 40. I weighed mine.
