Drag Racing Tech
Koni shocks + drag= Fail?
Old Oct 7, 2008 | 12:11 AM
ZMONSTER!'s Avatar
Default Koni shocks + drag= Fail?
Hey fellas Im currently running Koni 4/4's and strano springs. I origionally wanted to build a road course car but now Im more interested in drag.
Question is are these shocks and springs good for drag? If not how much of a hinderance are they?
I want to really get the nose up. I was running a 35mm front sway but that came off this last weekend.
Im also running the usual sub frame connectors, adj TA, adj panhard bar, 9 inch and Im getting my stock LCA's boxed and welding on relocation brackets later this week or the next. With that Im using MT et streets 275 40 17 tires.
So what should I change to get a good street/strip setup?
Thanks!
Old Oct 7, 2008 | 12:59 AM
krazy4's Avatar
That actually sounds like a pretty good setup.
The ET streets should hook up nicely.
Old Oct 7, 2008 | 01:36 AM
ZMONSTER!'s Avatar
Oh they do!
I just need the relo brackets now cause my LCA angle is jacked up!
Old Oct 7, 2008 | 08:17 AM
FASTFATBOY's Avatar
My Koni Da's work VERY well on the rear of my car.
Old Oct 7, 2008 | 11:32 AM
DTB_LS1's Avatar
I recently cut a 1.69 60" with stock springs and Koni 4/4s in my M6 car. My 1.69 60" was with a soft launch with the front swaybar still in the car and on MT 315/35/17s. I have also just removed the front swaybar and I think I can easily cut mid to low 1.6s with a harder launch.
Old Oct 7, 2008 | 11:54 AM
ZMONSTER!'s Avatar
So stock springs would be better than the strano springs?
Old Oct 7, 2008 | 12:15 PM
'99bluez's Avatar
stranos lower the car which is bad for drag racing - so yes stock would be better.
Old Oct 7, 2008 | 12:19 PM
ZMONSTER!'s Avatar
you guys that are running knoi's, what setting are they at? Right now my fronts are at full race andthe rears are at 3/4.
Old Oct 11, 2008 | 08:00 PM
barryta33's Avatar
hey im running the same set up, should i set the rear shocks full soft ?
Old Oct 11, 2008 | 10:04 PM
DTB_LS1's Avatar
Mine are set at full soft in the front and one turn from full soft in the rear.
Old Oct 11, 2008 | 11:00 PM
ZMONSTER!'s Avatar
What are considered the best springs for drag. I kinda wish I still had my stock stuff!
Old Oct 12, 2008 | 11:10 AM
DTB_LS1's Avatar
I think alot of guys are using either stock springs or v6 springs.
Old Oct 13, 2008 | 12:11 AM
ZMONSTER!'s Avatar
Seriously considering trading my strano springs for someones stock springs and a little cash.
Old Oct 13, 2008 | 09:12 PM
ZMONSTER!'s Avatar
So Running my konis full soft in the front and full tight in the rear with stock front and rear springs should launch pretty well? Or should I just put stock springs in the rear and keep the stranos in front?
Im kinda looking to mix and match between stock parts and my koni/strano setup for best launch.
Old Oct 13, 2008 | 10:41 PM
ZMONSTER!'s Avatar
ttt...
So whats up koni/strano front and koni/stock rear or koni/stock all around?
Old Oct 14, 2008 | 11:07 AM
DTB_LS1's Avatar
[QUOTE=ZMONSTER!;10283960]ttt...
So whats up koni/strano front and koni/stock rear or koni/stock all around?[/QUOTE
If you want good handling and good weight transfer ar the track I'd go with konis and stock springs all around. I'd also start with the konis at full soft in the front and one turn from full soft in the the rear.
Old Oct 15, 2008 | 12:03 AM
ZMONSTER!'s Avatar
well I was going to pick up a set of stock shocks to fiddle with but my clutch went out this morning so I guess that has taken priority as of now.
Anyone reccomend a good street/drag clutch? Centerforce didnt work too well.
Old Oct 15, 2008 | 11:08 AM
DTB_LS1's Avatar
I currently have an LS7 setup and it's a great clutch on the street but it's starting to slip badly at the track so I will be swapping to a Mcleod RST twin disk this winter. If you have the money to spend I would suggest a Mcleod twin or a Textralia. You could also go with a Spec 3+ and save a little money. I would do a search in the manual transmission section and make an imformed decision on what clutch fits your setup and budget.
Old Oct 15, 2008 | 12:48 PM
85Iroc's Avatar
Lowering a car is not bad for drag racing....... depends on how it's done.
Old Oct 15, 2008 | 03:15 PM
Unstang's Avatar
True, my car is lowered w/ BMR springs, I have stock shocks & have cut some 1.51 60' times...I know there are guys with lowered cars going faster than me.
