New Solid Roller Dyno results! 600RWHP!!
Pains car has a 1.80Promod gear set in a powerglide and it had 4.10 gears out back.
! A Dyno Pac or a Superflow Chassis dyno are awesome for tuning. Being able to hold the motor under any load at any throttle position allows you to tune that thing in perfect. Sounds like this motor was built up the right way.
At a steady state your going to see the motor restricted by the TB earlier on in the HP curve since it will make higer numbers than on an acceleration run. I wonder what numbers you guys would get at a 300rpm and sec pull and a 1000rpm a sec pull? Was the 600rwhp on a steady state pull? If so the numbers will be a little lower if you do it on a Dynojet, I'm 100% on how much lower. Still it's a dam good job considering that's going thru a glide and a big rear end! Probably close to 750HP at the flywheel.
Bret
Dman it was cool to watch these guys go at it.
Zoo Tycoon the chassis is already certified now all we need is the driver to get his license.
Great numbers!!!
Can't wait to see the times it lays down.
