How's this for some D1SC numbers?
Old 12-01-2008, 03:43 PM
Tuner@Straightline's Avatar
Default How's this for some D1SC numbers?
Car is a 2002 Z06, stock bottom end/heads, custom ground cam and supporting hardware, headers, catback, 3.90:1 gear, and a D1SC supercharger kit with a 4.00" pulley. At 6500rpm, it's making about 14lbs of boost. We'll be changing the pulley to get about 12lbs later this week. Car is using HPTuner's 2bar OS and numbers are on our Mustang MD-1100SE dyno.
Numbers are 591@6326rpm, and 537rwtq@5236rpm.
Attached Thumbnails How's this for some D1SC numbers?-c5z06dyno-002.jpg   How's this for some D1SC numbers?-c5z06dyno-001.jpg
Old 12-01-2008, 04:22 PM
fastvet's Avatar
Nice!!!
Did you lower the compression??
Old 12-01-2008, 04:27 PM
PREDATOR-Z's Avatar
Old 12-01-2008, 04:37 PM
Originally Posted by fastvet
Nice!!!
Nope, stock compression, that's why we're going to lower the boost just to have a little more insurance.
Old 12-01-2008, 10:57 PM
lilbuddy1587's Avatar
Incredible! Would it be possible to employ some kind of restrictor plate or waste gate so that you would be able to continue using the smaller pulley and take full advantage of boost ramping up much quicker, while also being able to bleed off excess pressure?
Old 12-01-2008, 11:12 PM
JRracing's Avatar
Gotta love the D1SC..
Old 12-01-2008, 11:26 PM
SS DNA's Avatar
Wow those are good numbers!
Old 12-02-2008, 02:14 AM
BlkBird2000's Avatar
I'm almost better off buying a procharger instead of heads/cam/nitrous. Still won't be where this is.
Old 12-02-2008, 06:26 AM
bad95killer's Avatar
Very impressive results on MD man
Not quite sure but Isn't that gonna heating up the air and running a huge amount of parasitic loss at that PSI level ?! just curious as you're lilbuddy ?
peace
Old 12-02-2008, 07:34 AM
fastvet's Avatar
Im just amazed that you can run 14lbs. of boost on a 10.5:1 C/R and not blow the engine!! I thought the most procharger recommended on that compression was about 9lbs???
Old 12-02-2008, 07:50 AM
forcd ind's Avatar
still amazes me the hp diff on setups-your almost 100hp/torq over what i dyno'ed on mine, lq4 w/d1sc, pp stage 2 heads, cam, running a carb
im not sure i believe all the dyno #'s out there, but i ran an 11.1, then switched out the old tight converter i had, ran 10.68 @ 125(picked up in the 1/8)
so that car should easily run 9's, i would like to see the 1/4 times
not downing your setup by any means, i just see some huge #'s out there
either i missed the mark or something, but i was on a milder tune up
curious what the cam specs were-i know im a little weak there, 224/228, 580/590 on a 114-im thinking maybe a 112 cl would be better for torq
im running a 4.25 pulley, have a 4" im switching to-i had about 12.4 lbs boost befor the i/c'er, 9.6 under the carb, about right for the lose thru the i/c and carb-where are you measuring boost on the FI setups?
i run a modified vette procharger setup in a chevelle
again, not downing the #'s, wish i had them, 100 hp increase would make me scrap my stroker build, lol-although i feel i need the torq for my 4l80e im building
Old 12-02-2008, 08:44 AM
We have used restrictor plates before, ECS includes one in their C6 Novi Kit. We had to employ one on the last one we did, we were seeing 12lbs of boost at 5500rpm, with the restrictor we saw 12lbs at 6500rpm. For this application, the customer wanted to pulley it down.
The plugs look great, even #7, so if something were to blow it'd be the head gaskets (cylinder pressure) or something on the bottom end. Just to be safe that's why we're pulleying it down to 12lbs.
You got to remember this car is using a manual, plus were your pulls done with a locked converter? The cam in this car is about the size of yours if I'm not mistaken. Now this is the highest numbers I've gotten from a stock bottom ended car, but it's also the most boost we've seen on one. The last two FI Z06's that made 550rwhp with 9lbs of boost have ran 1/4's with trap speeds at 131mph and 135mph respectively.
Old 12-02-2008, 08:50 AM
sciff5's Avatar
I believe it... in fact I dont know why these are "big" numbers
Vseriestech's old P1SC setup made 600+ or 650 whp at something like 7.5lbs of boost on a stock shortblock.
Old 12-02-2008, 09:37 AM
LS1Tech Sponsor
Slowhawk's Avatar
Nice,I love the boosted Z06's.Add meth and turn timing up and I bet you'll see 700rwhp out of that thing just like we did a few years back.Car even lasted over a year like that.
Old 12-02-2008, 09:46 AM
LS1 SPEED's Avatar
am I save assuming Perry's car / my old car ?
good #'s and it should be fun
We have used the A@A kit on a few cam, bolt-on Z's this past summer and seen 600-615 rwhp with approx 10 psi.
Old 12-02-2008, 10:42 AM
forcd ind's Avatar
i run an old school switch/pitch turbo 400, dual stall, in the chevelle-it is a
13" converter, with a 1300/3000 stall-i didnt switch to the tight stall on the pulls-when i ran it, i could see on the lm-1(rpm converter) it was only stalling at 2200
i borrowed an ati trans/converter, closely matched to my engine, thats what i used for the quicker pass, dropped the 60' down to 1.58
im only running 9.2 comp, prob could turn up the boost a lot more and get some better #'s-i dont think the carb is hurting me much on wot compared to the FI
my afr's were in the 11.20 range, tr6 plugs, 21 deg total-all looked good
those MPH's def. prove out the hp readings your showing
i just thought i would see more hp that 488 rwhp with what i had
i guess i cant worry to much about it, its just a street car, and cant use all the power it has on the street anyway, lol
now my old 68, 540 F2, 907 rwhp w/110, that was an animal, lol
Old 12-02-2008, 12:28 PM
PewterScreaminMach's Avatar
Wow, that's some serious power in such a light car. First thing I'd do is take it out and romp on some KB Cobras.
Old 12-02-2008, 07:35 PM
98blueSScamaro's Avatar
very good numbers Mike
Old 12-03-2008, 01:04 PM
registered user
ScreaminRedZ's Avatar
Great numbers! Those LS6's are damn impressive.
I've seen people use a wastegate setup with a centrifugal supercharger to get the power in quicker, but keep the boost from going through the roof up top. It gives it a big turbo like curve. I think I'd try something like that if I put a blower on any of my cars.
Old 12-03-2008, 01:21 PM
sciff5's Avatar
There seems to be lots of the vette guys that go with a procharger and get great results but shouldent the F-body guys with the lower compression 241 heads be able to push a little more boost and thus a little more power (even though the heads dont flow as well)?
Quick Reply: How's this for some D1SC numbers?
