The great header debate continued. 1 3/4 vs 1 7/8
#41
No, same primary lengths, I saw the same gains Ed did, 2-4, but loss of 10 at 2500-3k.
Shorter 1 7/8s pick up almost 10 uptop, but again, lost over 12-15 in the midrange. By mid range, Im not talking peak Tq, Im talking 1500-4000.
I have graphs, but Im not at liberty to share at this point. It does follow what you would think it would do, thats for sure.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
#42
I can't help but think the split cams that the L92/LS3/LS7 like so much may affect a test like this. How much different do you think the results would have been on a cathedral port car? Thanks for taking the time and posting the results!
#43
I still think its impossible to make blanket statements about the header size.
Initially I had cheapo Edelbrock 1 3/4 stepped to 1 7/8 with 3.5" collectors.
I "thought" my 454 could benefit from a larger "quality" header. I went with AR 1 7/8 stepped to 2" also with 3.5" collectors. The car lost almost 1tenth and over 1/2 mph. Keep in mind this is track testing with a very consistent car that made almost 100 passes this summer. This is no few passes one set, a few the next.. I'm talking "corrected" averages with over 40 of those passes made after the switch. The car has a 5k converter in it so the "loss down low" really isn't a factor either.
![Engarde](https://ls1tech.com/forums/images/smilies3/engarde.gif)
#44
I "thought" my 454 could benefit from a larger "quality" header. I went with AR 1 7/8 stepped to 2" also with 3.5" collectors. The car lost almost 1tenth and over 1/2 mph. Keep in mind this is track testing with a very consistent car that made almost 100 passes this summer. This is no few passes one set, a few the next.. I'm talking "corrected" averages with over 40 of those passes made after the switch. The car has a 5k converter in it so the "loss down low" really isn't a factor either.![Engarde](https://ls1tech.com/forums/images/smilies3/engarde.gif)
In your case I think the only real way to tell would be to put the others back on and see if it picks back up.
#46
I'm not knocking the test or your opinon but we did it back to back same day not months apart and we lost TQ with the bigger header too just like 1cdub did,does that mean it will happen to everyone?
No....
Don does make a good point that cam and or what heads are on the engine come into play too..IMO its not one header fits all,but in our case the 402 we built likes the smaller tubes
No....
#47
No....
Don does make a good point that cam and or what heads are on the engine come into play too..IMO its not one header fits all,but in our case the 402 we built likes the smaller tubes![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
No....
Not knockin your test or opinion either, but it's funny how many people talk about them loosing torque or power, but little or no real data to back it up.
I've yet to see a significant drop in power using larger tube headers. Even hot rod magazine or one of em anyways, did a test of 1 5/8 vs 1 3/4 vs 1 7/8 and picked up each time they stepped up. Not once did they drop even low end torque.
All I want is to see a graph, from you or anyone else. Engine dyno, chassis dyno, whatever. Same brand, same primary length, only change being tube diameter.
#48
You def have a bad *** car, no doubt. But I've been around drag racing all my life, and I cannot believe a 454 inch motor would ruin better with 1 3/4 primaries than it did with 1 7/8s. Not to mention the fact that it's hard for me to believe that 1/8th inch of primary diameter would knock almost a tenth off it.
Facts are facts, I've got almost 100 slips showing the average diff. between the two with my particular combination.
Keep looking for graph and dyno sheets, I gave you a real world example.
#54
from what ive read all over here and learned from useing ls3/l92 heads is they dont flow so well on the exhaust side so a bigger header was always suggested.
thats what ive read on here, so if u had a different type of head i.e like a pair of ls6's on a ls6/2 and did the test it would prolly be different?
or am i mistaken.
just curious
or am i mistaken.
just curious
#56
PipeMax recommends an exhaust gas velocity of around 260fps. So something in that speed range would be the target. That would give you the best overall power under the curve. There is quite a bit of latitude. To fast or to small a header and you go into sonic choke. To slow or to big a header the torque starts to drop off and reversion becomes a problem.
#57
Moderator
Nice to see the test. I was lucky enough to test 3 different headers on the same car and tune them to max performance on a 03 Z06. My test showed the 1 7/8 making more hp everywhere. The other 2 were 1 3/4 size headers and there was a big difference between the 2 in the low end area.
Haven't done any back/back on the 05+ Vette's.
Hey Don,
I'm guessing the two 1 3/4 headers were different lengths?
Was one of the 1 3/4 the same length as the 1 7/8?
I've recently been playing around with Performance trends engine analyzer, specifically working with headers, diameter and length. It's quite interesting what it spits out are the optimal headers for different packages.
Here is an over lay of my current headers vas what it feels are optimal headers for the most average TQ and also optimal headers for the most average HP based on my combo ans 2500-7400rpm.
Current headers 1.875 x 32"
Optimal TQ 1.622 x 50"
Optimal HP 1.737 x 37"
Then if you change the RPM band and only the rpm band to 4,900-7,400 which is where my motor runs while racing it give much different numbers. Again an over lay of the optimized HP, Optimized TQ and current.
Optimal TQ 2.363 x 37"
Optimal HP 2.438 x 35"
As you can see, there are minor difference between the optimized set ups. For the large RPM band, my current headers are leaving a lot on under the curve power according to the program.
Just some toying I thought was interesting.
#58
I just read this thread for the first and I'm wondering how everyone if everyone including me is dense regarding the OP's original post. I think the point being made is that out of four total tested vettes (being identical in config.) two dynoed less than the other two. But in each case of comparing two vettes, the 1 7/8ths headers made up for the weaker stock vettes in the comparison to equal the total gains of the 1 3/4in headers (400 peak rwhp). In other words the 1 7/8ths picked up 35rwhp on the two weaker vettes while the 1 3/4 headers only picked up 25whp making all four cars about equal. I'm just wondering if I read it correctly?
