View Poll Results: How much will final tuning w/95 mm tb add to the base of 507/500 ??
1-2
8
21.62%
3-4
6
16.22%
5-6
11
29.73%
7-??
12
32.43%
Voters: 37. You may not vote on this poll
LG Motorsports 402 + Vengeance Ported 92mm FAST = 507 rwhp 500 rwtq first pull !!!
Im well into the 9s with DCR, SCR is ~ high 11s, I need to look up the build sheet again, I dont recall piston dish. I like flat tops though. and the heads are 58cc. I cleaned them up one pass before they went back on.
Advance is still 24-26* on pump
Oh, this is still through an 85mm MAF too... theres 15 going to an LS7 maf, or more going SD...........................
1 Post
Hmmmmmmmmmmmmmmmm, I am going to have to call and ask the boys at LGM. I wasn't planning on having a car with that kind of compression. Maybe the pistons don't come flush with the block, whats that called when the piston is at TDC and is still in the hole ?? Sorry if I sound stupid, its late and my memory is bad. I know I read about when pistons ATDC are out of the cylinder it raises compression, and when they are still in the cylinder ATDC they lower compression.
1 Post
Well Louis reading this, it sounds like last year when you had a few surprises for me and my motor before I picked it up. I appreciated your generosity last year and will again this year. Hook it up, I don't mind being LGM's poster child. LOL. I won't bug you about what you got planned, just do it brother. Can't wait to see what your ideas do for the final numbers.
If you go SD will I have any issues driving the car in June/July/Aug VS Oct/Nov with the major weather changes Michigan offers ??
LS1Tech Sponsor
I'm sure Louis got you covered.Also wouldn't worry if comp is that high.We have a few 12-1+ comp 408's out there and have a ton of miles on them just running pump gas.High comp. motors make some serious power,drive excellent,can easilly run smaller cams while making big power.Just have to watch the tune.I ussually run 18-20 degree's of timing on ours and make comparable power but timing goes around H/C design.
#34
1 Post
Thanks for the vote of confidence.
Can't wait to see final numbers when Louis is done with her.
