235/243 LSR cam results
#61
Was that the test and tune, Corky? I'll get the DA if you gimme a time/date.
#64
#65
Had the same duration cam with a lot more lift in it in my old 346. Good cam and ran like a raped ape once I put the FAST intake on it. It was paired up with a set of 243's and put down 45x/40x.
#67
2yrs old I know but what are some of these car's running NA at the track? My dyno numbers are quite a bit lower than most of these but with a slipping 4L60E still managed 11.7@116mph.
Here is the dyno graph from Holley LSFest 2011:
![](https://a6.sphotos.ak.fbcdn.net/hphotos-ak-snc7/310571_10150371117773343_500443342_10166687_1931323924_n.jpg)
And here is a dyno graph after a little AFR/timing tweaking on our dyno:
![](https://a3.sphotos.ak.fbcdn.net/hphotos-ak-ash4/407004_10150608622588343_500443342_11263048_1491913579_n.jpg)
#69
I went 11.41 @ 125/126 in better air and never got to run it again that year. Had the fast ported and went for a retune and had valve train issues on the dyno. Still working on clearing that all up
#70
I know this threads old, but just put this 235/243 113lsa cam in my LS1 383 stroker, made 322rwkw (431rhwp) and 660nm of torque through an 4l60e gearbox with a 3600 stall convertor and 3.07 rear diff gears.
have 1-7/8 headers and fast 102mm manifold/tb setup, ported heads and bigger valves.
Had torque and power curve basically identical to the first dyno graph on page 1.
Got a decent choppy idle and goes like a rocket when the throttle is applied.
