New dyno results from a header change
Old Mar 4, 2009 | 06:41 PM
  #41
1989GTA's Avatar
"7hp and 5tq is about what I would expect to see on a Stock cubed motor with a 1 3/4 to 1 7/8 swap. I don't think it has much to do with brand."
I would be interested in the differences between the collectors of the two headers. That might have more of an inpact than the size of the primary tubes.
Old Mar 5, 2009 | 05:02 AM
  #42
vettenuts's Avatar
Originally Posted by blu1
here is the latest update from getting a couple of the springs tested. I'll just copy and paste what Jonathan told me.
I just got a couple of springs off and tested and they deffinately have issues. The springs look like the typical .650" lift springs from patriot or TSP and should check 140 lbs. @ 1.800". Anyway, the first one checked out fine, and actually had 145 lbs. @ 1.780 which is how they were installed. The other one however came in at only 120 lbs. @ 1.780. If you stand them up beside each other you can litterally see that it is a little shorter that the one that checked good.
I will say these definitely have less than 5k miles, probably more like 3k miles. He also said if you stood the two next to each other, one was almost an 1/8th inch shorter. WTF!
If you floated them, that can account for what you are seeing for difference in the springs that were removed as this will cause irreparable damage. I would either go PAC duals or take a hard look at the PAC 1518's with titanium retainers to get some mass out of the valve side of the valve train.
Old Mar 5, 2009 | 07:36 AM
  #43
blu1's Avatar
Originally Posted by vettenuts
If you floated them, that can account for what you are seeing for difference in the springs that were removed as this will cause irreparabledamage. I would either go PAC duals or take a hard look at the PAC 1518's with titanium retainers to get some mass out of the valve side of the valve train.
I am looking at the 1518's but the cost of the titanium retainers just blows my mine. Are you saying if I was to get the PAC duals steel retainers would suffice? The 1221's or 1521's?
Old Mar 5, 2009 | 06:34 PM
  #44
vettenuts's Avatar
Looks to me that you are trying to gain another 1,000 RPM. I would do all you can to lighten the valve train, short of valve replacement.
Old Mar 5, 2009 | 08:24 PM
  #45
blu1's Avatar
I went with the 1518's and titanium comp retainers.
We'll see what happens once it gets here. We are going to dyno with the new spring and retainers with the stock rockers and see how it does. If it all checks out ok we are going to try the yella terras and see how she does. Lets hope this works out and lets the car eat up top.
Old Mar 6, 2009 | 04:42 AM
  #46
vettenuts's Avatar
Hope it all works out. Post results.
Old Mar 6, 2009 | 06:50 AM
  #47
00 black ss's Avatar
Blu1, do you have any idle vids of that cam?
Old Mar 6, 2009 | 07:08 AM
  #48
blu1's Avatar
I will get some once the car is back in my possession.
Old Mar 6, 2009 | 09:22 AM
  #49
WKMCD's Avatar
Don't forget to calculate whether to shim them or not. My guess is you're going to need to shim them for best performance.
Old Mar 6, 2009 | 09:26 AM
  #50
blu1's Avatar
I will make sure nothing is over looked this time to get it right. Thanks for the heads up!
Old Mar 6, 2009 | 01:12 PM
  #51
alright thanks!
Old Mar 13, 2009 | 03:11 PM
  #52
FASST LN's Avatar
It's been a week so hopefully things are back together again. What happened, what are the results!?
My car is with Alvin right now. Got dropped off last night and my builder said they were working on another vette when he left...wonder if that was yours?
I'm really anxious to see how my car performs since it was nearly stock before and now its had h/c full intake and LT headers.
Oh, and I'm runnning the PAC 1518s on the AFR heads. Hopefully you'll have good luck with your springs too.
Old Mar 23, 2009 | 05:27 PM
  #53
blackz93's Avatar
Awesome! Now change those pushrods and get rid of that valve float!
