dyno results hurt!!
Ed is one of the premier LT1 tuners. You made the right choice going with him. I wish I would have made the trip up to Tulsa when I had my LT1.
1: the 600b blower is on the small side for that motor, i know procharger sais its fine up to 700 Hp, but my experience tells me otherwise
2: what is the pressure drop over your intercooler?? it could very well be that your engine only sees 4-5 psi of relatively warm charge...
and the rest of that hp is lost in the 4l80 (thats propably not in lockup right?) and the rear end.... the rest bit pf power is most likely lost in an exhaust that is too small, are you running straight thru, or chambered mufflers??
Your blower is kinda of small (smallest one from procharger for out cars) but I could see maxing out the blower and it making around 580rwhp with that drivetrain you have.
What is your pulley combo and the RPM you shift at. I will figure out your blower speed rpm.
Ben
here is a link to mediafire with my datamaster file with code 43 and original running
http://www.mediafire.com/?sharekey=1...4e75f6e8ebb871
here is a datamaster run of it after i cleaned plugs and turned code 43 off
http://www.mediafire.com/file/arm2tmrnn2y/383 lt4 10psi2.uni
Just messing man, I hope you get it all fixed up and everything, I've been waiting 2 years to see this thing at a track!
