dyno results hurt!!
---383ci LT4 with AFr 220 heads and lt4 RPM intake
---ATI procharger at 10psi
---3500 stall
---4l80e manual valvebody trans
---moser 9" with 3.60 gears and locker
---aeromotive fuel system
---hooker long tubes
ed did tell me to hook my wideband up and definately adjust spark gap down to .035 from .045.
we definately know it is not running out of fuel
from the dyno chart it definately doesnt look like a misfire would be occuring. doesnt sound like a misfire. but i know for a fact that a stock 383 will make 400 RWHP.
with my combination already with that information should be enough to tell everyone that i should be making more than 375RWHP and 378RWTQ please any input would be greatly appriciated please post or email pyronotic138@yahoo.com or catch me on aim pyronotic138.
any idea of what to do
Edit:Reading comprehension owns me. I re-read the op and saw that Ed tuned it. Sounds like it's time to move on to a mechanical issue.
-Shane
hydaulic roller comp cams-- .532 intake .546 exhaust
duration at .050----------- 232 intake 239 exhaust
114 LSA
cam installed at 110 degree centerline
1.5 roller rockers
8.0 static compression
383 CI LT4
10psi ATI P600B
AFR 220 heads 74cc combustion chambers
2.08x1.60 valves
-28cc dished pistons
please let me know if you need anything else spec wise. also attached is the dyno
dyno run was made in 3rd gear at a 1.1 ratio gearing on the 4l80. hits 10psi boost at 6000rpm
