Lets see some APS dyno graphs.
Old Mar 30, 2009 | 07:04 AM
venom ws7's Avatar
WOW ^^^^^^^ WHat octane???
Old Mar 30, 2009 | 09:32 AM
Tom@SpeedInc's Avatar
93 octane for low boost, 100 octane (pump fuel) for 12 PSI
Old Mar 30, 2009 | 10:10 PM
jeremym's Avatar
Why do some TT cars make more tq then hp and others make more hp then tq? Is it the cams?
Old Mar 30, 2009 | 10:30 PM
engine specs, turbo size, compressor map etc have alot to do with it.
Old Mar 31, 2009 | 06:50 PM
MY99TAWS6's Avatar
Here is another 402 with afr 225 and gt7 ling cam.
Same turbos..
ere are the Hp setting:
1.606rwhp -640trq - 7.6 psi. 91 pump gas ( my wife drives the car with no problems
2.656rwhp -670trq 9.0 psi
3.707rwhp -773trq 11.6psi
4.736rwhp -812trq 13. psi
Torque does seem a lot higher on it and since we have same engine size and think more compression in the above build pretty sure this guy had 9.0 it must be cam,heads or possibly timing giving it the higher torque numbers.But I think any bigger motor over a 346 will show at least equal if not a bit better torque than hp.
Old Mar 31, 2009 | 07:13 PM
jeremym's Avatar
Only 2 graphs?
Old Apr 1, 2009 | 11:08 AM
MY99TAWS6's Avatar
Fraser do you have that graph with more usual rpm numbers rather than speed on the bottom?
Old Apr 1, 2009 | 04:08 PM
KnightmareLS1's Avatar
I'll post mine up in a little while, gotta get to a scanner.
Old Jul 30, 2009 | 07:42 PM
flyinbluess's Avatar
can get a graph if need be but last week in arizona in 112 deg. heat..... i dynoed my bone stock 01 ss camaro with a turbo350trans 300 vig converter and an aps tt kit...... with 8lbs of boost...... 10 deg. of timing and pump gass it made 465rwhp and 455rwtq .
Old Aug 2, 2009 | 04:28 PM
edcmat-l1's Avatar
https://ls1tech.com/forums/dynamomet...s-tt-goat.html
