LS3 Swap F-Body: Am I down on Power
It just came on though. It had come on before the tune so I replaced it right before I got it dynoed and it hasn't come on since. It didn't come on during the Dyno runs that I know of, because I wasn't in the car and the tuner never mentioned it, so the computer shouldn't have been pulling timing tming correct? Well now it's back on with the same code so I am thnk that I replaced the wrong side. It said bank two but I am betting the wire that it thinks is bank two is going to bank one.
LS1Tech Sponsor
It showed 0 KR on the dyno pulls. Tried from 12.2:1 AFR to 13.1:1. Timing sweeps from 22 at torque peak to 24 at hp peak all the way to 26-29 showing a good bit of a gain. Then another degree on top of that netting zero found the happy spot. Ended up at 26-29 for timing and 12.6:1 AFR at torque peak and 12.9:1 at hp peak.
Same with the maf unplugged as I SD tuned it as well. Idles at 800rpm with 50kpa. I would say it is a well rounded tune that I spent about 4-5 hours on. ls7 show about 435 to the tires here. Dave's stock auto LS1 GTO made 298rwhp here and trapped 106@4000lbs. Have had full weight F-bodies trap 115 with 400rwhp.
TJ I didn't know you guys were a sponsor here!
I would definitely agree that it is an amazing tune and there was a DRAMATIC difference between the time I got there and the time I left. The car was smooth and pulled like crazy compared to me not being able to do anything below 2000 rpms when I got there. I am by no means saying that you did something wrong at all. I can vouch that he did everything he could to get more power out of it and I definitely got my money's worth. You were willing to practically bend over backwards until I was happy and I will definitely be back up there soon with the new intake and exhaust setup.
I was just wondering if anyone could see anything in my setup that is preventing me from getting a little bit closer to that 475rwhp. It may just come down to it that I just need to step up to better header and y/x setup.
LS1Tech Sponsor
Right on, I was just throwing in a statement about how out dyno reads a touch low. I agree there is a good amount of power to be found in the combo though.
At least you have a good SD tune as a base so when you do a intake don't be afraid to throw the maf in the garbage and never look back lol.
You have a beast with 435rwhp with stock heads and intake!!
