finally we finished , today 460RWHP tomorrow 700RWHP
good results mashallah
nice work mohammed
what piston reliefe you have there ?? Gasket thikness ??
i'm just trying to figure what is your current compression ratio
Also i'm woundering what would be the piston to valve clearance with that big cam and the 59cc champer ??
nice work mohammed
Also consider, the compression height Diamond uses is bit high, I'm sure the pistons are -.010" out of the block, or more. They're using a .051" thickness gasket. I'm showing 11.2:1 SCR.
Its a large cam, theirs bigger though
![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
thanks Abdullah
, waiting to prepare your bird ![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
yeah buddy , thank u too
We didn't expect this , after that i said to the tuner to re-run again but he said the tune is good and don't need to re-run again so we test the car at the street from a roll and the results ....
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
![Devil](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_devil.gif)
He has Diamond 11502 pistons with -2cc pocket, typically standard the pocket on Diamond shelf piston is .200" for the intake and .150" for the exhaust, it should have pretty great amount of PTV.
Its a large cam, theirs bigger though![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
![Thumb](https://ls1tech.com/forums/images/smilies2/thumb.gif)
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
hey guys , see the picture below and tell me if that the correct setup for the purge or not , maybe the installation of the purge cause graph like that ? i was doubting on this setup and thinking maybe the nitrous nozzles can't flow their duty as well , and i forget to say the tuner installed the jets 49N and 22F for both dual nozzles , is that correct ? or we must te re-tune again ?
![](http://img384.imageshack.us/img384/5889/image272.jpg)
sorry for the bad quality **** picture
#35
just curious its probably nothing but on the dyno video, right as he gets on it you see a burst of black smoke and it looked like the car jolted... im kind of a newb to some stuff
#37
Anyways, I'd just run the 9"... No more wasting time or money with the stock **** 10 bolt at your power levels. Especially with the M/T's on the rear.
You can either call Bob over @ EPP, or talk to Eric @ Midwest chassis and have him do you a Fab 9 setup.
#38
yep !
we installed another rearend with 3.2 gears , the reason that we did't installed 9 or 12 bolt its much expensive.
Lol, I was actually waiting for this as soon as the guy asked what rear end you were running and you said the stock 10 bolt...
