finally we finished , today 460RWHP tomorrow 700RWHP
UPDATED see post 16
Hi , from long of waiting for the parts we have finally finished from installing and tuned the car we are just waiting for the EWP to be arrived through 2 weeks , the car is 98 camaro M6 mods below
LS1 346 ci
Manley 6.125 rods
Diamond 3.905 pistons
Patriot stage II 59cc
244/250 spec'd by Fraser @ speedinc
42lbs injectors
walbro 255 fuel pump
3.7
cometic 051 thickness heads gasket
TNT F2 wet kit
Tick Performance master cylinder
hokker LT , flowtech y-pipe , magnaflow catback
fast 90mm with bigmouth 92mm throttle body
SLP underdrive pulley
Spec stage 3 clutch , GM LS1 flywheel
the car pulled out 460RWHP , tomorrow we will tune the car with 250HP and we hope for +700RWHP
this is a compilation for today's tests , i'll try to post the graph as soon as i can , when we test the car at the street it was so fast and i feel scared![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
http://www.youtube.com/watch?v=yzndjyuw0wU
thanks, Mohammed.
LS1 346 ci
Manley 6.125 rods
42lbs injectors
3.7
TNT F2 wet kit
thanks, Mohammed.
1 Post
I hope you used VASELNE when you shoved that big *** cam into that little 346 !!
I see why you are using such a big cam though, its a NITROUS car. Good job man. I like it, in fact I like it a lot !! 250 shot ------------> +230 rwhp +275 rwtq !
u make me laughing when u said vaseline lol , BTW i believe the TNT wet kit will gave him real 250RWHP coz we tried it in many cars , the torque will be above 250.
Patriot heads, through our experience on the dyno seam to favor early intake opening.
you're not the 1st. nor last to use those cam specs. You wanted to run those lobes with completely different LSA and ICL before we spoke.
Unless someone is going to solely run their car on spray, don't see a reason to go with larger exhaust lobe, the exhaust already opens at 59 BBDC
your not the 1st. nor last to use those cam specs. You wanted to run those lobes with completely different LSA and ICL before we spoke.
![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
I told you why I would go with 110 LSA, thats what we did.
FWIW I typically don't favor cams with such an early intake opening, in this case, thats what was needed.
hey guys here is the graph and video , the car was so spinning it must pulled +700RWHP , the rear tires are M/T 17/40/275
http://www.youtube.com/watch?v=xpcsSRZVwhM
what do u think guys ?
![Google](https://ls1tech.com/forums/images/smilies/google.gif)
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
![Devil](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_devil.gif)
[QUOTE=Fraser@SpeedInc;11882737]
Fraser you're beast i don't know how to thank u
![Embarassed](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_emb.gif)
