Race Proven Motorsports 580rwhp 520Tq CAM ONLY!!
This is the car that made 570 cam only before and i wanted to test the LSXR on it. We made a baseline today and it made 568(its 92 degrees in the shop) We left it strapped to the dyno and swapped intakes and im happy with the results.
http://www.youtube.com/watch?v=YfryDwPesbA
a correctly spec'd out cam
it not unusual to gain 100 rwhp from cam only setups in ls1/6 motors, why would it be any different w/ the ls7
also i think its not common right now as to everyone just going straight to h/c setups or just mild cams
Great Work Fran and RPM!!!
see you soon
-brandon
study the boards some more it been out since 06 an ls7 with all the bolt ons and cam with a spot on tune they can reach as high as 570 its been done before. Add a fast 102 intake and port it with a ported 102 NW TB and wala your at an easy 580 rhwp. Now send the heads to TEA and your over 600 rwhp.
We tested a ported FAST on my heads/cam car that makes ~600rw and it was still a restriction according to the KPA readings. It picked up considerable power under the curve but nothing over 6000rpm. Maybe the 102mm TB will help.
