Low dyno numbers w/ 228R
It's in your tune, for damn sure, to start. What is the duty cycle on the injectors? They are 11 years old...
You also need an LS6 intake.
Address those three things properly and you'll see 360-375 rwhp and that much torque too, pretty easy.
Which headers are they? ARH, Kooks, TSP, custom? There is no downside to the 1 7/8 primaries. LS1s like to breathe, both in and out, just need to tune for it. This is clearly the case with yours.
Don't be surprised if you blow this motor if you got WOT before a GOOD tune.
Well, on a nitrous tune, and an auto trans, with a stock intermediate pipe and a Blowmaster muffler, my car put down 362rwhp.
So yeah, those are low #'s.
Tune needs to be fixed, you NEED an LS6 intake, at least, and if your mileage on the engine is a little high, you may want to check into your ignition/spark/fuel system.
With this setup (if you had a LS6 intake) and a manual trans with a all motor tune, you should see around 375rwhp minimum.
