Is 482 on a Dynojet good?
Old Jul 26, 2009 | 12:33 AM
racecar's Avatar
Default Is 482 on a Dynojet good?
My first time on a chassis dyno today made 482 RWHP on a Dyno Jet.
Is that a good number? The dyno guy is old school with a ton of experience, he was impressed. I was happy with it.
377, SD tuned, FAST 90, LS6 GM CNC heads, Diamond flat top pistons, TSP 233/239 .600/.603 cam, headers, high flow cats, and Borla Turbo muffflers.
Does anyone know how much power is lost from a C5 drivetrain? What would that motor do on a engine dyno.
Old Jul 26, 2009 | 12:42 AM
venom ws7's Avatar
Yes its very good with your Mild H/C Congrats man.
Engine dyno close to 570HP.
Old Jul 26, 2009 | 08:25 AM
RJB01camaross's Avatar
Nice Numbers!! What is your C/R?
Old Jul 26, 2009 | 08:33 AM
CJDZ24_Z28's Avatar
Very nice!
Old Jul 26, 2009 | 12:01 PM
racecar's Avatar
Dynamic Compression is 7.99, that's with a .053 gasket, flat tops with 2.7cc valve pockets. Static is 10.6. I really wanted to keep this one low because my last motor with 8.9 dynamic was knock crazy.
Old Jul 26, 2009 | 03:28 PM
mike c.'s Avatar
Depends,I've been on dyno jets that gave me 30hp over a mustang dyno with no mod changes. go to the track and look at the mph vs weight of the car. that will tell you more. Nice numbers tho.
Old Jul 26, 2009 | 05:22 PM
Johnnystock's Avatar
Those numbers are very high!! gongrats on the build!
any dyno sheet?
Old Jul 28, 2009 | 12:10 AM
racecar's Avatar
I will scan the print out tomorrow.
Old Jul 28, 2009 | 12:54 AM
Screamin_Z's Avatar
that's pretty good but it could be better, but depends on the fuel u run. 8.5 DCR is premo for 91 octane. if u have the PTV clearance then I'd get a thinner gasket or mill the heads to get it. if u have to, flycut the pistons to gain that extra .5 DCR if it doesn't clear. pretty sure u'd be over 500rwhp if u did that. SCR doesn't matter unless ur running boost. DCR is what counts to make max hp on NA. 8.9 DCR is fine if u were running more octane....MAYBE if u were running 93 but def needed some more octane, 91 mixed with a lil 100 would have worked. what kind of fuel were u running on ur 8.9 DCR?
btw...what was the weather likewhen u did that dyno and what's ur alt?
really good setup, can't go wrong with a L92 and a "smaller" cam
Old Jul 28, 2009 | 08:34 AM
fastvet's Avatar
Nice results for your setup!
Old Jul 29, 2009 | 12:13 AM
racecar's Avatar
I had an LS6 with domed pistons and the same cam and heads, with 8.9 DCR. I ran 50% pump and 50% 100 race fuel and could never get away with more than 25 degrees. Remember this is a road race car, they begin to knock after about 10 minutes of WOT.
I tried that same setup with an .040 gasket with the same results. The 8.9 just did not work for me.
I am running 28 degrees with the new L92, and pump gas, DCR 7.99 could not be happier, no knocks yet, have not been on the track. I am going to try more timing to see what the limit is. It was 85 degrees when we hit the dyno, the number on the text page is 478, on the graph it shows 482 (corrected ?)
Attached Thumbnails Is 482 on a Dynojet good?-dyno-graph-001.jpg   Is 482 on a Dynojet good?-dyno-numbers.jpg
Old Jul 29, 2009 | 02:01 AM
blackedout drop ls1's Avatar
Good numbers
