COMP Lsr Cams
Old 09-20-2009, 01:54 AM
Austinma62's Avatar
Default COMP Lsr Cams
I was trying to do some research on the newer lsr lobes and dig some results up. I couldn't find anything on these cams. If anyone has some info could you share it?
Old 09-20-2009, 02:02 AM
Austinma62's Avatar
In particular i was looking at the LSR™, 277LR HR12 Good Street/Strip Camshaft w/ Wide Range.Cam specs are LCA 113 IC 109 dur at .050 lift 227/235 valve lift .614/.621. Does anyone know how streetable this cam is and would it be a good choice for a power under the curve cam?
Old 09-20-2009, 04:49 PM
RJB01camaross's Avatar
The LSR cams are a series of cams Comp put out. There are no LSR lobes.
Old 09-20-2009, 07:33 PM
PREDATOR-Z's Avatar
LSL or LSR are the same lobes.
Old 09-20-2009, 09:14 PM
SweetS10V8's Avatar
Were splitting hairs here, but LSR is the name of a series of cams that use LSL lobes from what I understand.
I have an LSR cam and love it. Its the most aggressive lobe Comp has in their catalog. Its almost like and LSK lobe with less lift.
Old 09-21-2009, 05:03 AM
PREDATOR-Z's Avatar
from .006>.050 XE-R is more agressive. Variance of LSL is 50 while XER variance is 49.
Old 09-21-2009, 10:32 AM
jegten's Avatar
IIRC, this is the cam we installed in a friend's 05 GTO A4. it is very streetable and very smooth idle. though we have not dyno'd it, it feels very strong throughout. as a matter of fact, he smokes the tires from a roll easily. hope this helps.
Old 09-21-2009, 12:10 PM
XtraCajunSS's Avatar
I've had extremely good luck with the LSr cams and with LSL lobed custom cams as well. You will not be dissappointed...
Shane
Old 09-21-2009, 01:24 PM
LS1Tech Sponsor
Slowhawk's Avatar
They do seem to idle better and have good drivability over XER Cams.
Old 09-21-2009, 07:50 PM
Austinma62's Avatar
Thanks man thats exactly what I was looking for
Old 09-21-2009, 07:53 PM
PBMFIsMe's Avatar
I just bought a 239/247 to put in a 408. Hopefully it will have great results.....have to wait and see I guess. Good luck with yours.
Old 09-21-2009, 07:57 PM
Austinma62's Avatar
I haven't bought a cam yet, i am still tryin to decide which cam I want to buy and if I should go with a heads and cam combo since im already going this far for the cam.
Old 09-22-2009, 09:59 AM
jegten's Avatar
you are welcome!
actually, i know for a fact he will be changing cams soon, since he had one spec'd for his new stroker. and he will be trying it in the current setup first. maybe he can cut a deal.
if you decide to buy heads, which ones will go with?
Old 09-22-2009, 03:31 PM
ramairws6's Avatar
Running a rather large LSL (LSR) lobe cam at the moment and love it. Alot of midrange torque and excellent drivability. Tuner said it was very nice to tune.
Old 09-22-2009, 04:18 PM
exploder's Avatar
I have an LsR grind I would be willing sell if anyone is interested...I picked up about 30rwhp over my old cam. Specs are 239/255 114lsa with .620lift on both intake and exhaust. Pm me if anyone is interested in picking it up.
Old 09-22-2009, 07:22 PM
NemeSS's Avatar
Shane
are these lobes even more aggressive than the lsk? or do they fall in between the xe-r and lsk?
Old 09-22-2009, 07:33 PM
They are nearly identical to the LSK's but with less lift. The seat timing is identical. The X-ER lobes are actually more aggressive off the seat. All in all, the LSL lobes are an evoloution of the LSK for increased durablilty. They are much more forgiving IF you go into valve float. Float the valves with LSK's and you'll be shopping for all kinds of goodies fairly quickly...
Shane
Old 09-22-2009, 08:10 PM
ramairws6's Avatar
They have a huge base circle and are very slow off the seat but ramp super fast after. Oh, forgot to mention...........alot quieter valve train on the LSL also.
Old 09-23-2009, 01:24 AM
jegten's Avatar
mind sharing specs? or close to them?
thanks!
Old 09-23-2009, 03:21 PM
ramairws6's Avatar
thanks!
Sorry, if I told ya I'd have to take you out.......................
Quick Reply: COMP Lsr Cams
