2000 camaro dyno what ya think?
I think there is a lil work still to be had on my tune.. but here are all the numbers..
mods
ls1 stock short block (fresh with only 2000miles on it) with arp rod and main bolts
patriot stage 3 5.3L heads
vodoo 228 duration .567" lift cam
1.75 ratio roller rockers
hardened pushrods and ls7 lifters
kooks LT headers 1 3/4" tubes
2.5" to single 3" exhaust flowmaster 40 muffler and no cats
ls1 intake and stock tb (yes i know it kills but its still what i got)
stage 2+ spec clutch
MSD plug wires and bosch +4 platinum plugs
12 bolt rear end with 4.10 gears and a locker
SLP LID and descreened MAF
this is with a t56 6 speed car of course, with 275/40zr17 tires on the rear.
future mods will be in near future:
LS6 intake and ported TB
125hp nitrous wet kit
dyno numbers are below.. if i can scan the sheet i will, on a mustang dyno so numbers are at rear wheels on a 4th gear pull.
max power 397.7hp at 5100 rpm
max torque 430.76ft/lbs at 4600rpm
rpm- hp/A-F/torque
2500- 41.75/14.54/87.01
2600- 145.8/14.53/294.46
2700- 194.8/14.09/378.94
2800- 211.3/13.43/396.47
2900- 221.3/12.94/401.23
3000- 231.9/12.82/405.98
3100- 240.8/12.88/407.87
3200- 247.7/12.95/406.55
3300- 255.5/12.98/406.60
3400- 266.7/13.0/411.92
3500- 279.5/13.01/419.41
3600- 289.9/13.0/422.83
3700- 296.2/12.98/420.37
3800- 299.8/12.97/414.32
3900- 304.8/12.97/410.51
4000- 314.4/12.96/412.71
4100- 325.2/12.95/416.46
4200- 333.3/12.95/416.80
4300- 340.8/12.96/416.27
4400- 350.7/12.95/418.60
4500- 364.4/12.91/425.38
4600- 377.3/12.87/430.76
4700- 384.8/12.86/429.91
4800- 385.7/12.9/421.97
4900- 387.9/12.94/415.80
5000- 394.2/12.99/414.02
5100- 397.7/13.01/409.39
5200- 389.5/13.02/393.73
5300- 379.2/13.01/375.73
5400- 377.9/13.03/367.57
5500- 385.7/13.07/368.36
5600- 368.6/13.13/345.68
5700- 219.0/13.38/201.73
thats where we stopped it for now. the timing ended up being 4 degrees retarded also. the cam builds power to 6700rpm or supposed too but we were falling off quickly so we figured the ls1 intake was killing us so we quit till we get a good intake..
any thoughts?? or even guesses what will happen once we get the ported tb and ls6 intake on it??
mods
rpm- hp/A-F/torque
went to the track after tuuning above, and 3 days later i was doing this at the track..
r/t- .671 (sucks i know but i havent raced in ages)
60'- 1.963
300'- 5.346
1/8- 8.104
mph- 88.66
1000'- 10.425
1/4- 12.365
mph- 117.11
this was ran on regular goodyear street tires. nothing special at all (i never hooked at all 1-2-3-4 gears i spun on) im shocked i got below a 2.0 60' time but once i got above 3500 rpm it spun in every gear) I think this car has a lot of improvements what do you guys think with the dyno above and this time sheet here (this was the best time of the night also)
60'- 1.963
300'- 5.346
1/8- 8.104
mph- 88.66
1000'- 10.425
1/4- 12.365
mph- 117.11
what kind of numbers do you guys think will be had when i do the ls6 intake? also since the cam supposed to make power to 6700 will it be doing so once i put the ls6 intake on? cause it drops off good after 5200 rpm now.. ls1 intake to blame??
and finally does the 5.3L heads kill my performance too? should i look for a set of ls6 heads and sell my 5.3L's??
also do you think the motor will handle a 100-125hp wet shot?? if so any guesses on et's if im able to hook up?? on and off the bottle??
id love to be around 440whp on the motor alone, with torque around the same if not higher.. but i dunno if i can with my combo safely without a power adder..
Yeah I have coil overs, torque bars and I just put on mt street radials.. I'm hoping that I will crack some good 11second passes on just the motor n deep 11's on spray..
Glad to know my hp n tq will go for longer with a ls6 intake, I was sure the ls1 was killing it quickly.. Hell I may see even higher numbers with the ls6??
