LS3 Cam only, E85, 507 WHP
Old Jan 20, 2010 | 05:34 PM
mike c.'s Avatar
You did nothing but convert to e85 and gained 50+HP?????
Old Jan 20, 2010 | 06:06 PM
deedubb's Avatar
Well, the inline pump, e85, and tuning netted that. The e85 allowed me to increase my timing by 7-8 degrees.
Other factors that may factor in are that I was already supercharged and elevation here is 5300 feet. Not sure if that matters though.
Old Feb 28, 2010 | 10:16 AM
hymey's Avatar
Whats your PTV clearance must be a bee's dick lol
Old Feb 28, 2010 | 03:20 PM
SkullV's Avatar
Nice numbers man! That Pro Dyno Tech dyno can be generous though! (but I love my numbers from it too!)
Old Mar 2, 2010 | 11:06 AM
Spoolinsteve's Avatar
Holy freaking win. I thought dynomites were on par with dynojets?
Old Mar 2, 2010 | 12:38 PM
gc302047's Avatar
Originally Posted by mike c.
I was tols e85 don't burn like gas and puddles in the intake and was not good on a performance car? Any thoughts,this was said by the people who tune my car.
WOW! they said that, Retards go get a new tune from someone else
Old Mar 2, 2010 | 03:09 PM
TT632's Avatar
He's blown and if he was running methanol the gain would have been larger. Blown applications with alcohol always have gains due to the cooling affect of alcohol (latent heat of vaporization is over 2 times that of gasoline). Another benefit is that the alcohols contain a small amount of Oxygen.
Typically, if you have a low to medium compression ratio, you will see a very small gain vs. gasoline. As you increase the compression ratio of your motor, you have a much hotter charge that benefits from the cooling effects of the alcohol.
Old Mar 2, 2010 | 05:29 PM
Seems the general consensus about e85 is that they will make more power almost always than an equal octane race gas assuming the fuel system can handle the demands. Something about the corn juice just doe not want to detonate. Numerous reputable FI shops will agree if they have alot of e85 setups come through to get tuned.
