MS3 Cam /TEA 5.3l 2.5 Heads
Well thanks to all the perks of being deployed and not paying taxes, I bought a whole bunch of go fast parts. I am also in need of a Dana S60 4chl if anyone has one, it would be greatly appreciated.
N/A 434 RWHP/ 389RWTQ as of last night at EFI Alchemy. Video and pics comming soon.
TEA 5.3l Stage-2.5 Heads
MS3 CAM, Dual Springs
Fast 92 Ported-Intake
Vengeance 92mm Ported-TB
Fuel Rails
42lb flow-matched Lucas Injectors
LS7 lifters
HD timing Chain
Hardend Push-rods
LS6 Valley
Hooker Super-COMP Ceramic Coated LTs
No Cats/ EGR delete
3" ORY
QTP Electric Cut-out
Flow Master Exhaust
Lid
160 stat
150-SHOT NX WET KIT
Mickey Thompson ET
and of course no car is complete with out some "Free-mods."
Fuel Rails
LS7 lifters
HD timing Chain
Hardend Push-rods
LS6 Valley
No Cats/ EGR delete
3" ORY
Flow Master Exhaust
Lid
160 stat
150-SHOT NX WET KIT
Mickey Thompson ET
if i am not mistaken, TEA is Total Engine Airflow. Those are good numbers. With that NX kit that thing should make some insane power, close to 600whp i would think. I just looked again, the torque number seems kinda low. i would be interested to see the graph as well.
Dynojet 224. I don't think the Slowmaster catback was helping. We'll open up the cutout tonight and see what benefits are to be had there. We have been working on drivability as that takes a lot more time than WOT.
#'s are almost identical mine when I had my catback on. Now with TD's they should be higher. Your cam is a little bit bigger. How does it drive on the street? I want to see the graph and compare to mine. Should be a real fun ride though!!
Tune is on the conservative side of life-I believe in longevity, reliability over the ragged edge of seeking numbers. Cutout was open last night, picked up about 10 over closed thru the slowmaster. The owner is planning on coming back from overseas duty and taking a cross country road trip. With the stock clutch, transmission I didn't see the point of spooling it past ~6krpms.
Good numbers I see you are from Ft.Lewis would you happen to be with 4/25 (I think that is what it was) in Baqubah? If so you replaced me. Anyways good numbers and good choice on going for a safe tune over numbers. Numbers dont mean anything if it blows up!!
A stock T-56 transmission shouldn't have anything to do with how high it's pulled on the dyno. I've spun a T-56 to 7K on the street for 3 years straight. I could understand the clutch issue, but if it's not slipping now then there's absolutely no reason the car shouldn't be spun to peak.
damian took the words out of my mouth what the hell does clutch/tranny have to do with "spooling" it past 6000 rpm....stock LS6's go to 6600 with the same stuff...btw that is one odd looking tq curve and looks like a complete slug until 3500; can we see a graph with zero smoothing? it appears the the mag jagged curves there may be some valvetrain instability going on...also would be interested in seeing SAE numbers
Well, I think, because it has a stock clutch, if he reved it up, the clutch would of slipped. I know stock clutches arent rated in handleing high horsepower applications. Not to mention How many miles were on the clutch to begin with. ....thats just what im assuming
