82 Corvette LS1 6 speed DYNO RESULTS!!!! Got more than I expected
Just wanted to post what I was able to put down on a Dyno jet after my LS1 T56 swap.
Engine is a 2002 LS1 with 135k Miles UNTOUCHED internaly
Bolt ons include
85mm Maf
Custom Intake
18lb flywheel
Melrose Long tube headers
3 inch duel exhaust with X pipe
Flowmaster 44s
Custom Tune
Engine is totally stock still running LS6 intake, stock unported throttle body
I was hoping to get 300Hp and 300Tq with the setup now especally with retaining my AC and all other creature comforts and a IRS rear end
Well I can say I am more than happy with the results
I got 338 HP and 350TQ on the last run, and buy probably would of got more because the warmer the car was getting the more power it was making.
so I was well above my goal of 300/300 and am more than pleased.
I plan to shoot for 450 after a head and cam and underdrive pulley swap
Bolt ons include
85mm Maf
Custom Intake
18lb flywheel
Flowmaster 44s
Custom Tune
Solid numbers. I'd save some extra $$$ for a backup shortblock before you do the H/C. You're going to be on borrowed time with that high mileage bottom end. Of course the milder the setup, the less risk of spinning a bearing or whatnot.
it was a 82 crossfire I have a build thread on it in the hybrids forum.
I am not to concerned with the motor it still has the crosshatch in the cylinder walls and things looked clean. it does have a rear main seal leave though thats spraying oil all over my nice clean engine and trans. but the engine is stoute I ran it up to 7k rpm doing a burn out and it did not even phase it.
I do have plans for a 402 forged bottom end. I have also seen plenty do a head and cam swap on motors wiht more milage than mine.
I may just get a long block assembled but for what i want its 7k and I cannot afford that right now
Very nice numbers, that car's gotta be fun as hell! I bet there will be more than one person suprised as you pull away from them in your "Crossfire" vette, haha.
Going to check out the othere thread right now.
I will be replacing the entire motor at some point just not sure if I want to go with a 383 or a 402 ls2, price is not all that different.
