490/570 H/C/N2O through TH400
I believe that the AFR was great when it was N/A (13.03) as shown in the chart. Isn't? But on nitrous it was rich (11.31). So what is the best AFR range that I should be in to be safe both on nitrous and NA in your opinion??
And for the timing actually I don’t remember it, I have to get back to the tuner again about it.
What do you guys recommend the timing to be? I'm thinking about retarding four degrees since I'm gonna shot a 100, because as I know that the ignition timing should be retard two degrees of for every 50 horsepower of nitrous.
Appreciate your help.
Forgot to mention that the car was running on 95 octane fuel, TR6 plugs and open cutout in both runs I've upload. I don't know if that helps in determining the AFR and retard.
Could anyone help me?? please
I don't think your going to need any timing retard on just a 100 shot, I've heard its when you go over 150 shot you should start pulling timing. But if your really in doubt, pull a couple of degree or so, you probably won't lose anything really. As far as the AFR goes, I keep mine mid 11's. I don't pick up anything at the track when I go any leaner, and its better to error on the rich side unless your going for mpg.
