04 z06 TSP tsunami cam
Thank you. I relly did enjoy working with you and on your car. Give me a call when you are ready to do some upgrades so I can help you get what you are looking for.
I wish I could make it to the track to see it run!
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
And to the guy above me, I would have liked 430, but I am more than happy were im at, every dyno reads different, and this 416 hp is an honest number, no over-infalted tires, iced intakes etc. Drove it like 10-15 miles, straped it down and did the pulls.
Im 110% happy.
Went to the 1/8th mile track yesterday..... and............
was getting horrid wheel hop and clutch pedal stuck to the floor at the end of each run. Once was so bad, when i put it in neutral after the lights I could not get it back into gear at the end of the track, I had to coast into the return lanes and sit for a min or so for it to cool off before it would go into gear. I am going to get a tick adjustable master cylinder and pray it fixes the problem, i herd it takes 10+ hours to do a clutch on these vettes (
![MAD](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_mad.gif)
best run was a 7.8x @96.1 WITH A 2.1 60 foot, I litterally spun half way down the track, didnt hook up until the end of second. Slower than my 7.61@96.5 but that run had a 1.8 60 and hardly any wheel spin execpt for the 1-2 shift. Will update after I get the master cylinder in.
Added a udp (freshly cleaned airfilter..) and new numbers are 426/399 sae, same dyno warmer weather.
when it cools off ill get some track numbers. Previous best 1/8 was 7.61@96.5 Bolt ons (minus udp) untuned. We shall see.
tick master helped with the pedal sticking to the floor. the clutch doesnt grab like I want it to honestly, so we will see how it likes launches on a sticky surface when the air cools off down here. I do not have high hopes but I havent tracked it in over a year so I have the itch big time.
